Brake rotors warp every 2k miles 1993 Si hatch
Old Mar 6, 2006 | 05:16 PM
jedmtnman's Avatar
Default Brake rotors warp every 2k miles 1993 Si hatch
So, my Si has 207k miles on it and I have hardly every had to do anything to it. For the last 30k miles or so my rotors have come out of true more quickly than before (4 wheel disc brakes). But at 200k I had the standard tune-up done with timing belt, etc and they said my CV joints were toast (second set) so I had them do that and replace the front rotors (under spec). So then 2000 miles later, low and behold the rotors were warped again so i took it back and they said the back were underspec and the front was overbraking so it caused them to overheat, so i replaced those and turned the front. Now, another 2000 miles go by and the rotors are warped again and my teeth are about to rattle out of my head. Any one know what gives? It seems like as light as this car is i should be able to stop it by dragging my feet flintstone style! Car seems to drive fine just aweful rattling of the steering wheel braking over 40 mph, but it seems better braking at around 70 and under 40.
Thanks, Jed
Old Mar 6, 2006 | 05:25 PM
mxs's Avatar
mxs
Default RE: Brake rotors warp every 2k miles 1993 Si hatch
Welcome to the forum. What brand rotors and pads are you using? And does your car still have the original calipers? You can probably solve your problem just by buying better parts and breaking in the pads properly.
Old Mar 6, 2006 | 06:00 PM
riceburner700's Avatar
what i would do is...
new pads
rotors front and back
and dont just go flying down the road when you put the brakes on you have to ease into them for like 100 miles without any real hard stops...
Old Mar 6, 2006 | 06:02 PM
D16z6's Avatar
Plus the smaller the rotor the fast it will warp compare to bigger rotor. You should get slotted/cross drill rotor. It should help it last a little longer since they help draw heat from them.
Old Mar 6, 2006 | 06:10 PM
mxs's Avatar
mxs
Here's some stuff to read:
http://www.dallasimports.net/forums/...howtopic=11487
and some more:
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
Old Mar 7, 2006 | 07:42 AM
jedmtnman's Avatar
that's pretty good information. the calipers are stock, the rotors and pads are factory spec, nothing aftermarket. They seemed to work great the first 180k miles. Maybe I will get the rotors turned and try it one more time without any crazy stops for awhile but all i do is highway driving with no traffic so I am usually slowing down real slowly off the onramp or whatever.
Old Mar 7, 2006 | 10:02 AM
Getting them turned won't help warpage...
Old Mar 7, 2006 | 01:36 PM
jedmtnman's Avatar
fourty 04,
when i say turned, i mean turned in a laithe, so the rotor should be true again, but less material. when you say it won't help, is this because you did not understand my syntax or is there something else I should know? The stoptech link posted said that there would be some crystalline change in the rotor is this what you are refering to?
jed
Old Mar 7, 2006 | 01:41 PM
mxs's Avatar
mxs
I think everyone should read the links I posted above, and I wish I had read them last summer [:@]
Old Mar 21, 2006 | 03:06 PM
neon3kgt's Avatar
be sure that they are torqueing the lug nuts properly... grand ams have problems with the front rotors warping easily and thats one of the things we have to do to help with it.
