how do i keep my sub from sliding?
Old Apr 19, 2006 | 08:45 PM
rmvols31's Avatar
Default how do i keep my sub from sliding?
ive got 1 12 inch sub in my trunk with an amp mounted to the side. ive moved the amp all around the box but i cant seem to keep my sub stable in the trunk. it slides around with every little curve. i cant find anything to bolt it down to. just need some advice.
Old Apr 19, 2006 | 08:53 PM
01CivicEX's Avatar
Default RE: how do i keep my sub from sliding?
i just used those velcro earthquake straps. you can buy them anywhere and they work good
Old Apr 19, 2006 | 09:00 PM
rmvols31's Avatar
ok cool ill give it a try thanks
Old Apr 19, 2006 | 10:48 PM
01CivicEX's Avatar
no problem. yeah it hold my 2 12" subs and box which weighs about 110 lbs
Old Apr 19, 2006 | 10:52 PM
RaskyR1's Avatar
you could bent some 90 brackets and use some small screws...depending on the trunk of coarse.
Old Apr 19, 2006 | 11:24 PM
n8te81's Avatar
when i had my 3 piece box but in i had them bolt it down to the trunk from inside the box...i did that for that reason and so if anyone broke in they would spend at least an hour if they REALLY wanted my subs and box...lol.I can kick it and it doesnt even budge.
Old Apr 20, 2006 | 01:07 PM
aliefnate's Avatar
velcro has worked for me
Old Apr 20, 2006 | 01:09 PM
Remmy's Avatar
Take the sub out of the box. Postition the box where you want to. pop in screws form inside the box. Put sub back in box. Your done and it looks clean
Old Apr 20, 2006 | 02:30 PM
Roost3r's Avatar
ORIGINAL: RaskyR1
+1
Old Apr 21, 2006 | 12:02 PM
amg6975's Avatar
The false floor on mine caved in from the weight or the box and everything so I just took it all out and put a board on the bottom side of the false floor then drilled through the board, cardboard crap and into the box... fixed the floor and kept the box from moving at the same time.
