Fuel issues with turbo
Old Jul 23, 2006 | 07:03 PM
Skrapdoggydog's Avatar
Default Fuel issues with turbo
Will a high flow in line fuel pump be able to supply enough fuel for my b16A @ 7lbs of boost? do i need bigger injectors? fuel rail etc?? Right now i am sputtering at WOT high boost?????? Thanks for any help
Old Jul 26, 2006 | 10:16 PM
dfdon's Avatar
Default RE: Fuel issues with turbo
injectors!!
Old Jul 27, 2006 | 08:12 AM
WHat injectors are you running? And what fuel management? Are you running untuned?
Old Jul 27, 2006 | 04:38 PM
i am running stock injectors and a fmu that came with my turbo and a high flow fuel pump. I already ordered rc 440cc for my baby. plan on soon (2 months) ordering the hondata unit maybe the S300 what do u think?? should i get tuned after i install my injectors or after the hondata ??? Thanks for ur help!!
Old Jul 28, 2006 | 08:55 AM
You should probably get it tuned after the injectors. You should also upgrade the fuel management right now, FMU's (at least in my opinion) are pretty risky.
Old Jul 28, 2006 | 01:26 PM
Can u get a stock ecu tuned? My B16A came out of a 94 del sol so i guess I have an OBD1 correct? I always thought u needed to have something like hondata, neptune etc. in order to get tuned. Is my car gonna run like s*** with the 440cc injectors without a tune? Right now with just the bigger fuel pump it pulls good but you can tell it is holding back.
Old Jul 31, 2006 | 11:23 AM
zerocool's Avatar
Get your equipment and get it tuned... safest way to go man.
Old Aug 2, 2006 | 12:16 AM
VTECivic95's Avatar
injectors than retune!!!!!!!!
Old Aug 2, 2006 | 09:42 AM
seroiusly, get your ecu chipped and tuned, safest way to go
Old Aug 2, 2006 | 10:36 AM
riceburner700's Avatar
get the injectors and a tune will lay down way more power to and be safe
