D16y8 vs D16z6
Old Aug 17, 2006 | 01:30 PM
curlybandit's Avatar
Default D16y8 vs D16z6
Just wanted to do a D16 comparison.
I was wondering if you guys can add some things to the pros vs cons list that I was making for these two motors. I was looking at them in relation to my '96 Si. I'd like to know what the real differences are between the two. Obviously I might be wrong on a few, but please feel free to correct it.
D16y8:
Pros:
- many aftermarket parts
- easy and low cost to repair
- reliably boosted at low psi
- low cost replacement (~$500)
- can keep OBD2 ECM for '96 Si
- better flowing intake manifold design
- better flowing exhaust manifold
Cons:
- can't tune OBD2
- weak oil pump
- weak rod bearings
- boost can be risky due to above
- worse head design
D16z6:
Pros:
- OBD1 can be tuned
- stronger oil pump
- stronger rod bearings
- can handle more boost, more reliable to boost
- low replacement cost (~$500)
- better head design
Cons:
- slightly less power that y8
- need to get OBD1 ECM
- need to get harness for OBD2-OBD1 conversion
- more restrictive intake manifold design
- more restrictive exhaust manifold design
What else?
Old Aug 17, 2006 | 01:37 PM
thedougler's Avatar
Default RE: D16y8 vs D16z6
the y8 has steel shift forks compared to aluminum on the z6 the steel are way stronger
Old Aug 17, 2006 | 01:41 PM
all it takes is a chipped ecu and a conversion harness to convert to OBD1.
The y8 also has known bottom end oiling issues...
Old Aug 17, 2006 | 01:50 PM
finalimpact's Avatar
z6>y8 nuff said..............only thing i like about the y8 is the combustion chamber in the head.....
Old Aug 17, 2006 | 01:51 PM
Remmy's Avatar
And there isnt such a thing as an '96 Si
Old Aug 17, 2006 | 01:53 PM
ORIGINAL: Remmy
The '96 EX Coupe in the US is called the Si in Canada. Maybe should have mentioned that. It has a D16y8.
Old Aug 17, 2006 | 01:57 PM
Kedawei's Avatar
I don't think the oil pump is the problem with Y series, it's small oil passages. Also I don't know about the Z6 oil pump either.
They both make about the same power. 2HP is negligible.
No ODB converting is necessary with the Z6 if you just get the OEM harness (which may be included with the swap, as well as the ECU).
You're right about the stock exhaust manifolds.
The head design is better on the Z6 from what I've seen, but the Y8 intake manifold is better than the Z6.
Will add more later, gotta run.
Old Aug 17, 2006 | 03:25 PM
ORIGINAL: Kedawei
That's interesting, because I've actually heard it the other way around. That the flow on the y8 is better
Old Aug 17, 2006 | 03:51 PM
t34me's Avatar
Yeah, i think kedawei is confused, it has been pointed out many times the y8 combustion chamber is a step up over the z6, but id still go with the z6
Old Aug 17, 2006 | 04:00 PM
riceburner700's Avatar
i still love the z6 over the y8, just seams more user friendly
