"Seat" questions on EX...
Old Sep 25, 2006 | 03:14 PM
kremmily's Avatar
Default "Seat" questions on EX...
Hey! I have a few questions about my seats in my Honda Civic 2002 EX:
1. The driver side seat jiggles back and forth even though it locks. I have tried to remove the seat, but i don't know how or what to do about it. Any sujestions??
2. What are the cables under the driver seat for?
Thank you everyone!
Old Sep 25, 2006 | 03:20 PM
mxs's Avatar
mxs
Default RE: "Seat" questions on EX...
1. try lifting up your floormats, they are probably only held in by 4 bolts.
2. seat belt sensor
Old Sep 25, 2006 | 03:37 PM
Chimera02EX's Avatar
This happened to my seat as well, after a while I got uneasy about the seat if I ever got in an accident so I replaced it. I got a racing seat, but over the winter I'm putting in a roll bar so I have that much more safety.
Old Sep 25, 2006 | 04:24 PM
kremmily's Avatar
Ohh! So i just have to take out the 4 screws. I got it.... what's that seat sensor you talk about? what is it for? what about my "rocking" problem? is there a way to fix it? do i have to adjust something?
Thank you buddy!
Old Sep 25, 2006 | 05:19 PM
mxs's Avatar
mxs
the seat belt sensor is for the "idiot light" in your dash that tells you to buckle up.
I can't say what you will have to do to fix your seats, since I don't really know what's wrong. But you can check if the bolts are loose. they should be torqued down REALLY well.
Old Sep 26, 2006 | 10:57 AM
kremmily's Avatar
Thank you very much for your help guys!
The problem is that the seat locks, but when you sit down it literally rocks back and forth. It is a slight rocking movement, though, it is kinda annoying. I would say it is just an inclination of a few degrees. Any sujestions????? (The seat is in optimal conditions and clean)
Old Jul 2, 2008 | 07:29 AM
belias's Avatar
I have the same, 02 ex. I was just about to post the same problem, let me know if you got it fixed and how! Its extremely annoying
Old Jul 2, 2008 | 08:53 AM
My04Civic's Avatar
Administrator
note to you ...that was posted 2 years ago
Old Jul 12, 2008 | 10:32 AM
kremmily's Avatar
What up brother. Hey, the only thing I did was.... NOTHING! I just decided to leave that the way it is. I tried to pull the darn seat outand also tried to adjust it, but my skinny, weak fingers did help much. I just thought "what the heck, I will spend more time fixing other stuff." The seat problem is not too much of a problem. Capicci? At least for me.
I hope this helps my friend!
kRem
Old Mar 7, 2010 | 08:58 AM
tgs's Avatar
tgs
...and here I am a year and a half later, my seat rocks back and forth very slightly too. Will check the bolts. If they are tight, then it will stay that way!
