Replacing stock struts question
Old Feb 8, 2005 | 01:19 PM
89civiclx's Avatar
Default Replacing stock struts question
Hello! Thread #2.... My first one was in the new section. So I have a 1989 Civic LX and the truts are dryrotting and worn out, they're probably stock... I want to replace the struts with something dependable for my son to use later. Then I look around in the forum and see Struts, Coilovers, Shocks, Strut bars etc.... I don't wan't the car to be a show car or race car, just dependable and sturdy. Don't need to drop it but if that happens (no more than 1") with no side effects, okay. Maybe some of you can make some suggestions; I know this is an older car that a lot of you don't deal with anymore, am I right?
Thanks in advance....
Jerome[sm=patriot.gif]
Old Feb 8, 2005 | 01:28 PM
Remmy's Avatar
Default RE: Replacing stock struts question
well you dont need anything that belongs in a ferrari. Just go to ebay and score a cheap set, you ought to get rear struts too. but if im wrong somebody should correct me.
Old Feb 8, 2005 | 01:31 PM
Kappa22's Avatar
I would recommend two options. You can either go OEM, or KYB makes a pretty good OEM replacement that will tighten up the ride a little without changing anything else.
Old Feb 8, 2005 | 06:44 PM
yeah, KYB or a set (all 4) of Tokico Blues (HPs) that should make it handle a little better, but shouldnt set you back too much.
Old Feb 8, 2005 | 10:06 PM
89civiclx's Avatar
Thanx, I just looked around on EBay and saw those listed. . . . 'ppreciate the help.
Old Feb 8, 2005 | 10:12 PM
no problem, come on back whe you have another question, maybe we can help out your son by convincing you to put a few higher performance things on it
ORcivic
Feb 14, 2007 07:25 PM
Safety_Driver
Jan 8, 2007 09:16 PM
kar83
Feb 26, 2006 01:50 PM
guf
Jul 14, 2005 09:33 PM
Josh1122
Mar 31, 2005 11:30 AM
