Question about Z6 intake for my turbo'd D16
Old Oct 24, 2006 | 04:42 PM
WhtRice's Avatar
Member
Default Question about Z6 intake for my turbo'd D16
I'm turbo'ing my 00 D16y7 and am switching over to the Z6 intake for tuning reasons as suggested by 40, should/can i switch to Z6 cylinder head as well? what all is involved or should i stay just with the Y7 head and Z6 intake?
Old Oct 24, 2006 | 05:32 PM
Kedawei's Avatar
Default RE: Question about Z6 intake for my turbo'd D16
Do a search for "mini me." The Z6 head will benefit you and the swap is not difficult.
Old Oct 24, 2006 | 05:47 PM
WhtRice's Avatar
Member
well i found alot about putting a Y8 head on the y7 block but nothing about Z6 head/intake on a Y7 block. basically i ask because this guy is selling a port and pollished Z6 head with
well i'll let you read
"the head has been ported and polished with larger intake and exhaust ports. exhaust ports have had the dividers knife edged for better exhaust flow!
this head is complete it comes with vtec selenoid & valve cover along with a complete valve train. this head came off a car with low miles! "
basically i can snag it off him for about 100.00 and i'll have vtec then right? what else is involved i cant help but think i need to buy an Apexi Vafc or something, is there a tie i can't find? or am i just over analyzing something very simple??
EDIT>> ahh ok so i read up a little bit more and it look slike i'll need the wiring from the Z6 and the ECU gotcha. now for ECU should i buy stock or is there something aftermarket?
Old Oct 24, 2006 | 06:11 PM
Kedawei's Avatar
You can buy stock and chip it for the tuning (cheaper), or buy aftermarket. There are several aftermarket options out there, but I'm not very familiar with them, or tuning really. Personally the best value I've seen thus far is having a tuner tune a chipped stock ECU with NepTune. There's not a whole lot of NepTune dealers out there, but it's a great program, one of the best. Dealers usually charge about $500 for the system itself and tune.
Don't forget the vtec soleniod there.
Old Oct 24, 2006 | 06:16 PM
WhtRice's Avatar
Member
yea says comes with the Vtec solenoid, so as far as wiring goes, if i buy an OBD I Skunk2 ECU will that have all the "wiring" i need for this swap or is there a seperate harness i have to buy?
Old Oct 24, 2006 | 06:34 PM
StifflersMom's Avatar
Cat Fuсker
You know, I would stay with the y7 head. My reasoning for that is that there's less moving parts and tuning is definitly easier without variable lift.
Old Oct 24, 2006 | 06:38 PM
WhtRice's Avatar
Member
ORIGINAL: Roto
However will I not pull more power out of Variable lift when i turbo it in the long run there'll be more whp with a Z6 head valvetrain and intake correct? tuning is a non issue to me.
Old Oct 24, 2006 | 08:39 PM
Cat Fuсker
I think a y7 with z6 manifold is comparable to a z6 with z6 manifold. N/A z6 is better, but turboed it will not make that much of a difference.
Old Oct 24, 2006 | 11:04 PM
Kedawei's Avatar
I've always been a proponent of the Z6 head design over the Y series. Vtec will allow him to run a calmer idle also.
Old Oct 25, 2006 | 12:47 AM
WhtRice's Avatar
Member
and an aftermarket camshaft. i cant find one for the Y7
