Direct port nitrous?
Old Feb 24, 2005 | 08:17 AM
illyont's Avatar
Default Direct port nitrous?
Anyone have installed direct port nitrous before? Wet and Dry shot of nitrous is well known, but it seems direct port isn't.. Anyone know the technical differences of those three? How do they affect performance, and can you get them street legal? Can you run stock internals with turbo and nitrous? Or would that blow something up?
Old Feb 24, 2005 | 01:00 PM
polo708's Avatar
Default RE: Direct port nitrous?
Haha, I think you asked just about every nitrous question there is... all in about 2 lines.
Old Feb 24, 2005 | 03:30 PM
Swift's Avatar
Actually direct port nitrous injection is pretty well known. The direct port nitrous injection puts out the most horsepower out of the three
about 200+hp. Th The wet system is the second most powerful, producing about 75-100hp, and the dry system is the weakest producing only about 50-75hp. From what i know in Georgia, all three are llegal. Also unless your engine came equiped with a turbo, you wouldn't want to run a turbo with nitrous on say a civic or integra. Good performance parts such as forged pistons, piston rods,......... SHOULD BE PURCHASED BEFORE you try and put both in a car like that. And even with a car like a Supra, you wouldn't just want to throw a Direct Port kit on it and and let it ride.You might have some problems and you might not.
Anytime!
[IMG]local://upfiles/488/CE6603A996D34FEF95675B6450C55000.jpg[/IMG]
Old Feb 24, 2005 | 04:34 PM
Remmy's Avatar
thats incredible... ive never seen anything like that
Old Feb 24, 2005 | 07:52 PM
Kappa22's Avatar
Nitrous purge is one of the sexiest things in the world... right up there with BOV dumping and the boost threshold.
Old Feb 25, 2005 | 03:34 PM
Roost3r's Avatar
cant wait to get my spray...do you guys think i should for wet or direct on the f20b accord motor..
Old Feb 25, 2005 | 07:27 PM
just do wet. direct will be WAY more expensive, and isnt necessary for the power levels youll make without a full build.
Old Feb 28, 2005 | 08:03 PM
riceburner700's Avatar
can you run like the lowest shot into a 16valve motor like i am trying to do or will you damage the engine, because i dont want to hurt anything under the hood its my everyday driver. like the dry kit
Old Feb 28, 2005 | 08:52 PM
im pretty sure the lowest setting is around 75 horses.
Old Feb 28, 2005 | 10:48 PM
like if i ran that shot in my car would i freeze er up or would it drive away just fine if you just used a little bit here and there like on the weekends and stuff like that if i felt like it,
