adjustable shocks???
Old Nov 24, 2006 | 12:01 PM
ic892003's Avatar
Default adjustable shocks???
what is the difference between hp tokico nonsdjustable shocks and tokico illumina adjustable shocks??? i do not understand what is meant by the shocks are adjustable, someone explan please
Old Nov 24, 2006 | 12:09 PM
drbyers's Avatar
Default RE: adjustable shocks???
good lord...
Old Nov 24, 2006 | 12:10 PM
Belmont's Avatar
Adjustable
Tokico Illumina adjustable shocks and struts were designed for tuning street suspensions. For the serious enthusiast, TOKICO offers 5-position adjustable shocks and struts called Illumina. The adjustment system provides you with the ability to set your car up for a variety of uses. Even so, some units work quite well on the race track. Steeda, a well known Mustang tuner, has used Illumina adjustables very effectively on both their road race and their drag race cars. The Illumina units not only work well, but Steeda people have been very pleased with their durability. A simple click of a screwdriver allows you to change for ride or handling balance. So whether you are going to the track, or simply cruising, the Illumina range of adjustment can adapt to your needs.
Non-adjustable
Tokico non adjustable shocks & struts. Conventional shock absorbers are among the simplest and oldest of shock designs. They are common on many trucks, older cars, and a few newer cars. They are also one of the least expensive shocks. Struts are units that combine the shock absorber with a stressed part of the suspension. The struts allows auto manufacturers to eliminate the upper control arm and upper ball joint. They use a large diameter piston rod and are quite a bit larger and heavier than conventional shock absorbers. Most struts also combine the lower spring perch or seat into their construction. Strut cartridges were developed as replacements for rebuildable struts. While they are still being used, most newer cars use what are called sealed or non-rebuildable struts.
sold in pairs Spring seat, coilover, and coil-around are all terms used to describe this shock absorber. While they look like struts, they are actually shock absorbers with spring seats mounted on the body. They are not only smaller than struts overall, their piston rods are 25% to 60% smaller than struts.
That took me 2 minutes to find. Please search before you ask another suspension question.
kk5150
Apr 18, 2011 09:17 AM
trustdestruction
Jan 11, 2008 04:57 PM
spintelect
May 17, 2007 04:23 PM
snosurfa7
Jul 10, 2006 10:06 PM
Syberfraggle
Jul 26, 2005 12:39 AM
