Wiring an amp question
Old Dec 17, 2006 | 11:17 AM
ian125's Avatar
Default Wiring an amp question
Ive got the Infinty basslink arriving on tuesday. its a 97EX and i just wanted to know how to remove the gray side step panel things to put the wires underneath it.
oh, also wheres the best place to ground it at?
thanks
Old Dec 17, 2006 | 10:20 PM
classiccarsrule85's Avatar
Default RE: Wiring an amp question
Well your first question I have no idea since i have never owned anything newer than '93 but id have to say its held in by either screws or pop-able clips....
And to your second question depending on where you decide to put the amp you could either attach it to a preexhisting ground, attach it to a bolt that holds the seats or something attach to the body of the car but make sure you sand off the paint first to get a good ground...or you can go the extra effort and drill a hole somewheres in the trunk area and make it so a bolt will tighten down to it and sand the paint around that area where the ground will be touching and bolt'er down....
Old Dec 17, 2006 | 10:21 PM
dukat03's Avatar
2 door or 4 door
2 door --- instructions
*1 remove your kick panel , there's a plastic tap in the middle remove it
2* remove the cap that's on your lock / unlock key insert where your trunk release is , there is a philip screw there
3* remove your B pillar (( that's the middle pillar )) ====pic below====
4* when removing the running board make sure that you look out for the trunk release it will start to catch on the panel when removing it .
5* you don't need to remove the back seat or the back pillar start to tug the wire around the seat towards the rear
when grounding the basslink don't ground in place of a stock screw ( example where the set belt bolt is ) make your own ground . the best place is right where your driver side rear straight tower is below that , just scrape off the paint and ground there {{{{{ make sure you don't use a long screw your gas tank lines are near there , use a half inch screw , a metal screw you can get 10 for a 1$ at your auto parts store }}}}}
4 door --- instructions
same as above you just have one more panel to remove which is the rear running board
[IMG]local://upfiles/16447/224EA77C231C4001BEC201863A19C2E1.jpg[/IMG]
[IMG]local://upfiles/16447/EBE6B6E7F2434D6784B80E6062C1B9C7.jpg[/IMG]
Old Dec 18, 2006 | 07:12 PM
ian125's Avatar
Hmm thanks guys. I kinda got a general understanding of what im doing now.
Welp, gonna try and install it tommorow when it arrives. Ill let ya know how i do..
thanks
Old Dec 18, 2006 | 07:43 PM
windcalmer's Avatar
Where are you mounting the amp?
Old Dec 18, 2006 | 07:45 PM
ian125's Avatar
I havent decided yet. The infinity basslink has the amp inside it. so wherever i can get the best sound. What's the ideal place for it?
Old Dec 18, 2006 | 08:27 PM
Method's Avatar
in your trunk.
Old Dec 18, 2006 | 08:36 PM
ian125's Avatar
DURRRR!
but like, right behind the rear seats? off to the side?? or will i just have to play around with it till i find the rite spot?
also, is it safe to drill anywhere in the trunk?
thanks
Old Dec 18, 2006 | 08:43 PM
2slo4u's Avatar
what are you drilling for?
Old Dec 18, 2006 | 09:01 PM
ian125's Avatar
so i can screw the mounting legs in.
