painting valve cover
Old Jan 28, 2007 | 12:15 PM
Tater's Avatar
Default painting valve cover
QUESTION NOW IS THAT.... is can I use engine enamel for the valve cover or do I have to use high temp paint?
Old Jan 28, 2007 | 12:27 PM
tdci29's Avatar
Default RE: painting valve cover
here you go...
https://www.hondacivicforum.com/m_88873/tm.htm
Old Jan 28, 2007 | 12:37 PM
Tater's Avatar
wow me = dumb thanks a bunch
Old Jan 28, 2007 | 01:05 PM
riceburner700's Avatar
i just had mine sandblasted for 15 bucks then took the high temp paint to it after it was blown off for a good couple coats
Old Jan 28, 2007 | 02:04 PM
Stumasters's Avatar
Shouldn't you replace your seals and o-rings and all that, before re-assembly?
Old Jan 28, 2007 | 02:12 PM
ej6buddy's Avatar
ORIGINAL: Stumasters
there are no seals or o-rings, just a gasket that can be reused if in considerable condition. clean the head with some degreaser and install gasket and put a dab of sealant in the corners around the cam housing to keep a good seal.
Old Jan 28, 2007 | 08:17 PM
ya dont forget those corners with the sealer.LOL i did and it leaks
still gotta fix that.... but i want to redue mine again so ive been putting it off... LOL
i just soaked my old cover in some diesel fuel for alittle while and kept brushing it till it got clean inside and out.....
and to finish it off some of that GREEN cleaner and a good garden hose
Old Jan 31, 2007 | 03:19 PM
rhdekhatch's Avatar
i have painted or polished all of mine. im actually still polishing one right now.
Old Jan 31, 2007 | 03:33 PM
Tater's Avatar
if its a red car with a red engine bay what color would stand out alot and would not look super ricey?
Old Jan 31, 2007 | 03:49 PM
ej6buddy's Avatar
just look at mine
