b16a1 parts info
Old Jan 30, 2007 | 07:13 PM
civtec00's Avatar
Default b16a1 parts info
i will be getting a 1990 civic hatchback dx, pretty soon. and i will eventually get a b16a1 from a jdm sir from online, i heard that the b16a1 uses the same parts(water pump, timing belt, clutch, etc.)as the b16a3, found in a 1994-1995delsol. is this true? thanks.
Old Jan 31, 2007 | 12:01 PM
Powermidget's Avatar
Default RE: b16a1 parts info
The clutch on the del sol was hydro and the a1 (gen 1) is a cable clutch so that is not the same....the timing belt is prob the same and i really dont know about the water pump
Old Jan 31, 2007 | 06:43 PM
civtec00's Avatar
so then i should look into a clutch for a 90-93 integra then, right?
Old Feb 1, 2007 | 11:41 AM
Just get a bseries act stage 1 clutch you just have to make sure it says for cable trans...
Old Feb 1, 2007 | 01:50 PM
finalimpact's Avatar
keep in mind.........the 90-91 cable transmissions use a different spline count for the clutch disc in comparison to the 92-93 transmission. you need to find out what year the engine and transmission is your getting.
Old Feb 1, 2007 | 08:06 PM
civtec00's Avatar
it it on one of the websites for jdm motors. it says it came out of a jdm89-91 civic/crx sir.
Old Feb 2, 2007 | 12:05 AM
assuming they send you nothing but an 88-91 engien and tranny combo...the 90-91 integra ls clutch is what youll need.
Old Feb 9, 2007 | 08:13 PM
civtec00's Avatar
i heard that i should get a clutch for a 92-93 integra gsr with the b17, because it is really the same motor, internally, and externally as the b16a1, and the clutch for the b17 is the same from as a 94 delsol b16.
Old Feb 9, 2007 | 09:35 PM
ic892003's Avatar
since ur buying the engine online, alot of the swaps include the jdm clutch, just use that one
Old Feb 10, 2007 | 04:16 PM
civtec00's Avatar
im not going to put a used clutch in a car, and than have to put another in. i want to put a stage 1 clutch in the car anyway
