Best Sandpaper to Use before Painting...
Old Mar 12, 2005 | 04:48 AM
corye03's Avatar
Default Best Sandpaper to Use before Painting...
As i'm sure you've seen I have most of my interior painted, I have painted something and it is peeling right now, I want to resand it and repaint it but I am unsure of what the best grit sandpaper is for the job, I want to sand all the rest of the paint off and start new...any suggestions?
Thanks Civic Tuners!
Old Mar 12, 2005 | 11:47 AM
Mossy's Avatar
Default RE: Best Sandpaper to Use before Painting...
3M's wet/dry sandpaper (the grey kind). use maybe 1000 grit if you're trying to remove paint
Old Mar 13, 2005 | 02:33 AM
jwsimons's Avatar
i dont think 1000 will leave a rough enough surface for good adhesion, its great to polish with, i'd go 400, and then after you paint polish it up 1000
Old Mar 13, 2005 | 05:57 AM
corye03's Avatar
use the sandpaper after i paint?
Old Mar 13, 2005 | 11:35 AM
yeah, 1000 grit is almost like regular paper, so it will just polish it up good, as long as you dont sand too hard or too long.
Old Mar 13, 2005 | 01:48 PM
corye03's Avatar
ah i see
i am going to paint and then cover it with gloss clear coat, do i sand after the clear coat or after painting and before clear coat?
also where can i get this? i looked at lowes and they didnt have any...
Old Mar 13, 2005 | 02:57 PM
most Kragen/autozone type places have it, and i think its best to sand everything but the final coat, as that will show the fine lines, but its paint, so you can pretty much just fix anything you mess up, as long as you dont REALLY screw up. just sand the paint, then clearcoat it, sand that, and see what it looks like. if it looks better unsanded, apply another coat of clear.
Old Mar 13, 2005 | 03:34 PM
corye03's Avatar
okay, thanks for the info man...
Old Mar 13, 2005 | 05:02 PM
Mossy's Avatar
actually, you do sand the final coat. thats how you achieve a "mirror finish" with painting. start with 1500, then 2000. and then after that it will be smooth but still with some fine lines. you use rubbing compound to polish out the fine lines left over and then apply some standard car wax to buff everything up once its cleaned off.
i suppose though that it won't matter if you're just doing some interior painting, unless you're really **** about orange peel
Old Mar 13, 2005 | 05:10 PM
ahhh, good call. i didnt even think of polishing compound...
