Small question...
Old Feb 17, 2007 | 11:15 PM
shopmanual's Avatar
Default Small question...
I've been looking through my chilton manual about the brakes, and one thing I noticed when I cleaned them off is that the manual says not to press the brake pedal, as this would cause the shoes to expand and make the drum very difficult to get back on. However, this makes the squeek I'm having trouble with to be very hard to find. I was wondering, would it hurt anything if I worked the parking brake back and forth, since that works manually without the brake cylinder? That would help. I think it's the pin that holds the parking brake mechanism in, but that would help me diagnose if that's really what's doing it. Any help appreciated, thanks.
Old Feb 21, 2007 | 12:01 AM
Kommando's Avatar
Default RE: Small question...
I would call the dealer and ask the service department for verification, but typically you're not supposed to press the brake pedal with the drums off because the wheel cylinders will over-extend and blow their pistons/seals. You may also over-extend some of the the springs, but that is not as likely. CAREFULLY using the parking brake might be a better option, as that does not typically move any part of the wheel cylinders.
brokenarmboy19
Aug 25, 2005 10:48 AM
mxs
Aug 9, 2005 01:08 AM
integramale2
Apr 27, 2005 10:33 AM
sacicons
Mar 8, 2005 07:47 PM
johnnyfamous
Sep 20, 2004 06:55 PM
