Where do I install oil catch can?
Old Feb 17, 2007 | 11:40 PM
10isAce's Avatar
Default Where do I install oil catch can?
I want to install my oil catch can. Where do I put it? I assume I put one hose to the valve cover and one to the intake pipe. But where do you all mount it. I think it needs to be vertical. Any suggestions? I posted a pic of my engine bay with the catch can just sitting near the intake.
[IMG]local://upfiles/4625/1179301CB97A486F8D0212AE16D6956C.jpg[/IMG]
Old Feb 18, 2007 | 12:05 AM
riceburner700's Avatar
Default RE: Where do I install oil catch can?
ok put a little filter on the valve cover.
take the catch can and run one of the lines to the pcv location on the intake manifold. Take the other and put it on the black box(pcv) on the back of the block.
basicly you are getting rid of your pcv system and cleaning up the air going into your motor
Old Feb 18, 2007 | 10:57 PM
10isAce's Avatar
I was wondering where to mount it. I think I'm just going to zip tie it for now to the intake pipe, to see if this really does any good.
Old Feb 19, 2007 | 08:01 PM
if you jsut put it one on the valve cover and one in the intake pipe it wont really be working how it should.
Old Feb 20, 2007 | 08:24 AM
10isAce's Avatar
ORIGINAL: riceburner700
Do you have a pic of this setup? Where is the pcv?
Old Feb 20, 2007 | 08:35 PM
the pcv is a hose that goes from your intake manifold through the intake manifold and into a black box on the back of the block
Old Feb 21, 2007 | 08:06 PM
10isAce's Avatar
OK, I hooked up the oil catch can wrong! What was I thinking? Anyhow I see where I'm supposed to put it, to the pcv valve and then to the intake manifold, is that correct riceburner?
Then am I supposed to put a tiny air filter onto the valve cover? I did that before and oil dripped out of it. Also on the air intakeside of the turbo pipe there is a opening as you can see in the pic for what I thought was the oil catch tank. What goes here?
[IMG]local://upfiles/4625/5DCA09592DFF4AEBB6E6D21DC66954D3.jpg[/IMG]
[IMG]local://upfiles/4625/A09CED7C084343C3BF3A3C3C291FB9DA.jpg[/IMG]
Old Feb 21, 2007 | 08:55 PM
what i would do..
cap off the air filter/tube
put a breather on the valve cover
hook one of the hoses to the intake manifold(pcv) and follow that hose to the black can under the intake manifold take out the hose and install the other hose from the catch can there on the black box
let me see if i can find a pic
oilltd
Jun 10, 2008 04:06 PM
Nerosync
Oct 26, 2007 05:55 AM
FlipHKD720
Jul 2, 2006 02:11 AM
Pete
Apr 18, 2005 12:54 AM
