Clutch/flywheel
Old Mar 17, 2005 | 09:05 PM
Swift's Avatar
Default Clutch/flywheel
I've installed a clutch before, though it was when i had already removed the engine. I'd like to know is it possible and easier just to get under the car and meunuver everything and replace the clutch then or just remove the engine.
[IMG]local://upfiles/488/0A27B72468CD4BD7BB539B2D6DA853CB.jpg[/IMG]
Old Mar 17, 2005 | 09:08 PM
AnakinKenobe's Avatar
Default RE: Clutch/flywheel
well on my 95 all i have to do is take off the tranny mounts side and rear and unbolt the tranny from the engine, now make sure u have a block of wood and a jack under the motor because with those mounts out the motor will move down and poof u can pull the tranny off, its easier said than done though but not to complicated
Old Mar 30, 2005 | 02:35 PM
vdog's Avatar
So does anyone have detailed instructions on removing and replacing a clutch?
Prices im getting are from 350.00 and up.
klppride
May 20, 2006 05:40 PM
redridinhood
Apr 27, 2006 10:43 PM
klppride
Jan 25, 2006 11:06 AM
skytanker2003
Jan 4, 2006 01:46 PM
01CivicEX
Sep 13, 2005 06:41 PM
