EP Swaps 2001+ Civics
New York Swap Shop
Old Mar 6, 2007 | 11:38 PM
CarmineD187's Avatar
Default New York Swap Shop
After doing quite a bit of research i have found out that the engine that i have in my car is about the worst honda engine ever made (Performance wise) So i have decided i'm going to do a K20 Swap but i have a problem, i live in New York ( The Bronx ) and the only shops i know of i dont trust them. So i was wondering if you guys knew any shops in New York that i could go to that are reputable and do good work?
Car: Civic 01 LX 4D
(A 01 Civic with a K20 swap)
http://cgi.ebay.com/ebaymotors/Honda...spagenameZWDVW
Old Mar 7, 2007 | 02:40 AM
TheMoogly's Avatar
Default RE: New York Swap Shop
That car you have shown is the most incredible thing I have ever seen. I applaud your find. Goodnight my friend.
Old Mar 7, 2007 | 08:18 PM
Belmont's Avatar
He has all those mods, and cant even spell vtec right.
Old Mar 7, 2007 | 08:32 PM
ic892003's Avatar
ORIGINAL: Belmont
[sm=exactly.gif]
carmine theirs a shop in queens that a lot of people recommended me2, its called rpm, their pricey i think $2400 for a full k20 shop but their work is good from what i hear...their located 217-85 98th avenue Queens village NY 11429
i went to them to boost my d15b7 engine..... they wanted $4k for the turbo kit and installation which i find to be to expensive, but hey check them out maybe u like them
Old Mar 8, 2007 | 01:22 AM
Thanks for the info IC8, but is it like yourprovide the Complete K20 motor changeover and theycover the rest of the small parts plus install for $2400? Most of the forums that i read and shops i'v been to charge $1000-$1200 to do it if you bring them everything. Other then ebay do you happen to know a place that sells the motor and the other parts needed for swap? Also does anyone know where to buy the engine that is in the newer 05-06 Type S or is it the same motor with some upgraded internals?
(This is the website that people say is good, any otheres)
http://www.hmotorsonline.com/shop/sc...amp;item=30015
Parts needed-
Complete K20 motor changeover.
Intermediate shaft.
K20 O2 sensors.
RSX or 02+ Si subframe.
Hasport mount kit.
Hasport wiring kit (if you have ***** of steel, you can wire it yourself).
Parts needed from an RSX-
Shifter cables.
Header and D/P.
Clutch lines.
Power steering hose.
Power steering return line.
Parts needed from an 02+ Si-
A/C line from compressor to condensor.
Axles.
Radiator and fans.
Upper and lower radiator hoses.
Other-
92-95 Civic power steering reservior.
92-95 Civic throttle cable.
Old Mar 9, 2007 | 04:19 AM
Another civic withK20 swap w/turbo:
Duane4238
Sep 16, 2010 06:08 AM
warchunks
Jul 24, 2006 05:48 AM
in2deep
Feb 12, 2006 11:55 AM
FRENUM822
North East
Jul 1, 2005 11:46 AM
Remmy
North East
Jun 8, 2005 02:48 PM
