Transmission rebuild...
Old Mar 26, 2005 | 02:24 PM
parsko's Avatar
Default Transmission rebuild...
Hey,
My old one is whooped. Synchros are shot. Just got a used one today. Thinking of rebuilding it. This is not above my capability. BUT, I do not have a procedure or reference to do it. I found a place mantrans.com that has rebuild kits for $225.
Has anyone done this, and could they provide me with documentation?
Or, does anyone know where I could find a rebuild procedure???
1995 D16Z6, 5 speed
-Parsko
Old Mar 26, 2005 | 02:50 PM
Kappa22's Avatar
Default RE: Transmission rebuild...
You can buy a used low-mileage tranny for $200 or less. Don't bother with a rebuild; there's too many things you could **** up.
Old Mar 26, 2005 | 03:34 PM
parsko's Avatar
There's not too many parts inside these things. I have rebuilt my dirtbike tranny plenty of times before, without an issue. Granted, I understand that a car tranny is a bit more complex, I still think it is within my grasp. I am mostly curious if things need to be pressed on/off, and if there is a schematic available.
One could only really mess it up is care is not taken to document where things go, the sequence, the clocking, etc...
I'm assuming this sort of documentation is not available. Maybe someone out there has a factory manual they could scan???
Old Mar 26, 2005 | 10:55 PM
D16z6's Avatar
yeah i agree with kappa just buy a used transmission. It ain't gonna be that pretty once you take the transmission apart unless you know what ur doing.
Old Mar 27, 2005 | 06:31 PM
Kappa22's Avatar
It's not a question of whether or not it can be done, it's a question of how many things you can **** up while doing it. I've never ****ed one up, but I don't rebuild Honda trannies anymore for precisely this reason: You're looking to spend around $250 on a rebuild kit vs. $200 on a used tranny and a whole lot less work... it just makes more sense.
Old Mar 27, 2005 | 09:45 PM
finalimpact's Avatar
[sm=badidea.gif] like kappa stated, there are too many little things that you can do wrong to tear up that tranny. i also build and rebuild honda transmissions and there even more complicated than your basic chevy 4spd. search your local import poerformance shops. you may be able to get one cheap as they wont store these things for long.
Old Mar 28, 2005 | 02:52 PM
Kappa22's Avatar
Actually, your best bet is to check out an importer of used Japanese parts. If you look around at those, you can get the best deals, good-condition parts, and bitchin' warranties.
Old Mar 29, 2005 | 05:04 PM
Roost3r's Avatar
id rather pull teeth then rebuild tranny..
Old Mar 29, 2005 | 10:45 PM
Kappa22's Avatar
Probably pays better...
Old Mar 30, 2005 | 02:04 AM
Roost3r's Avatar
i meant my own lol
