Sound of new header
Old Apr 13, 2007 | 03:37 AM
word's Avatar
Default Sound of new header
Alright so this weekend I installed a new edelbrock header with a new gasket on my 98 civic ex (d16y8) and it makes noise when I push down on the throttle a bit, kinda like a buzzing or farting noise but not exactly that coming from the engine(I'm not sure how to describe it and I don't my car with me right now). I don't really like the sound of it but the four people I asked say they think it sounds good and doesn't sound ricey at all. I had read on the forums here and other websites that a header is supposed to be quieter than the stock exhaust manifold. So whats up? Why is my header making noise? Is it possible to overtighten the bolts?
Old Apr 13, 2007 | 10:07 AM
cpl rampage's Avatar
Default RE: Sound of new header
it could be a leak between the header and head, or between the header and cat, are u runnign stock exaust?
Old Apr 13, 2007 | 02:35 PM
GReddy_Civic's Avatar
Snail'n Admin
i agree with cpl, check ur gaskets for leaks where u put the new header on, like spl said, between the header n head or header and cat
Old Apr 13, 2007 | 02:50 PM
word's Avatar
yeah the stock exhaust is still on. thanks for the replies
Old Apr 13, 2007 | 04:03 PM
Live_4it's Avatar
while it's running pop the hood and check the headerto see if you see any smoke leaking out, (don't touch it though!) once it breaks in some nuts might need some retightening.
Did you remember to put the doughnut ring on the end of the header connecting to the converter?
Old Apr 14, 2007 | 06:14 AM
word's Avatar
yeah i remember when i first started running the engine smoke was coming off of the header so i know what you're talking about. And yes I put the doughnut ring on the end of the header. I dont think the sound is coming from down below but is coming from the engine
Old Apr 14, 2007 | 10:42 PM
Live_4it's Avatar
If you just installed something (header) and all of a sudden your car is making weird noises why would your engine be suspect? Possible something could of gotten in the engine while you had the manifold off through the holes....but as soon as you start the engine it would be pushed out and through your exhaust.
I didn't mean smoke coming off the header during the breaking in process I mean like a bad weld and exhaust is leaking through a crack.
Old Apr 14, 2007 | 10:48 PM
word's Avatar
alright so I tightened the bolts connecting the header to the engine and have concluded that the sound is coming from down below where the header meets the cat. Guess that means I need to get under the car again . Thanks for the help
Old Apr 15, 2007 | 10:44 PM
Live_4it's Avatar
you know I get this noise when the engine is cold and I haven't ran it for awhile....I'm almost certain it's part of the heatshield reverberating off of the converter. Does it only happen to you when you start it up and the engines cold? Then go's away once it's at normal operating temperature?
Old Apr 19, 2007 | 08:37 PM
word's Avatar
no I get it even when the engine is warm
