02 sensor plug
Old Apr 14, 2007 | 03:40 PM
zoso's Avatar
Default 02 sensor plug
I have a 2000ex and got dc headers for it, the new 02 sensor plug is in the middle of the header, my question is where do i plug the other end into?
Old Apr 14, 2007 | 03:47 PM
ej6buddy's Avatar
Default RE: 02 sensor plug
primary-> header
secondary-> cat
Old Apr 14, 2007 | 03:48 PM
zoso's Avatar
Ya the header one where do i plug it into?
Old Apr 14, 2007 | 10:30 PM
zoso's Avatar
ANYONE
Old Apr 14, 2007 | 10:50 PM
wirphotos's Avatar
on 2000 EX the primary goes in the downpipe of the header right before the cat and the secondary goes into the cat. There should be a place to thread the o2 sensor in right on the top of the header by the engine and a second spot on the down pipe. You need to plug the top bung and put the o2 sensor on the lower spot.
Old Apr 15, 2007 | 02:02 PM
zoso's Avatar
I still dont see whereto plug the primary plug. it comes off the mid header and where does it go to, its a square plug. The other oneon the cat goes up into the car, help me!
Old Apr 15, 2007 | 02:52 PM
i know this is an ebay header, but its a good diagram
^ it has lines pointing to the 2 o2 sensor bungs, with the header you should have a gotten a plug for each hole like that picture shows. Plug the top hole and put the primary sensor in the secondary hole farther down the header, then i think you just leave the secondary sensor alone since you've got an EX.
Old Apr 15, 2007 | 03:10 PM
zoso's Avatar
ya the top one closer to you i pluged the sensor into it, now where do i plug the other end of that wire, it is a square block it has to go somewhere so it can read it
Old Apr 15, 2007 | 05:12 PM
there should be a harness that you plug it into just to the left of the header, the one you unplugged the sensor from.
Old Apr 15, 2007 | 05:41 PM
zoso's Avatar
Ok i will look, where does that wire go to?just incase i cant find it, i didnt put my header on
