View Poll Results: A poll
MSD
10.53%
Nology
21.05%
Accel
0%
Other (specify in post)
15.79%
Screw aftermarket-just go stock
52.63%
Voters: 19. You may not vote on this poll
Which Spark Plug Wires
Old Apr 21, 2007 | 03:30 PM
Default Which Spark Plug Wires
Well, I was removing my valve cover (to re-paint), I managed to damage one of the plug wires... the engine sounds like it's still hitting on all four cylinders (I started it up and let it idle for a few minutes after everything was re-installed to see how bad the damage was) and the rpm's are staying relatively constant... the thing is, I want to replace the ignition wires before it does start firing on only three cylinders. I figured that a stock replacement set will cost me $30 to $50, I might as well spend a little more and go aftermarket. Anybody have experience with brands that can help here?
Old Apr 21, 2007 | 04:12 PM
riceburner700's Avatar
Default RE: Which Spark Plug Wires
nology if you have the cash and like nice fat wires. lol stock will be fine unless you are like moddified up the wazzu
Old Apr 21, 2007 | 04:25 PM
well, right now I'm not that heavily modified (i/h/e), but in a year or two, I'm going turbo, skunk2 cam, low-comp pistons, etc, so I'm thinking I'll probably have to upgrade the wires eventually (along with the rest of the ignition); why not just do it now?
Old Apr 22, 2007 | 10:23 AM
Not worth it imo, oem replacements are more than sufficient, even with the "future mods" you've listed
Old Apr 24, 2007 | 02:37 AM
digimon916's Avatar
nology hotwires good??? they seem extreme to me...but these are the only wires that i have my eyese on. you guys hear anything positive or negative about them?? http://www.sigmaautomotive.com/HotWires/main.gif
Old Apr 24, 2007 | 02:43 AM
danomatic93's Avatar
June 2010 ROTM
NGK all the way!
Old Apr 24, 2007 | 07:09 AM
ORIGINAL: reaper2022
in a year or two you're probably gonna wanna replace the plug wires anyway
Old Apr 25, 2007 | 08:47 PM
Live_4it's Avatar
The more expensiveplug wireswill last longer and are more durable imo.
Old Jun 11, 2007 | 07:10 PM
civicman124's Avatar
Ihad a question related to spark plug wires......i was thinking about replacingmywiresandupgrading tosome nice aftermarket ones.I have a 1994 Civic Dx with an Aem Short Ram intake and i just replaced the plugs with Bosch Platinum 2and was wondering how much, if any performance gains i could expect to get from replacing my spark plug wires. Also, which ones would be the best value to get, cause i dont feel like spending $150 on Nology wires. Thanks
Old Jun 11, 2007 | 08:30 PM
June 2010 ROTM
Welcome to the forum, for future reference please start a new thread with a different question other than the one posted. It looks like you've found the search function useful thought.
Anyways, to answer your question, you will not feel a performance gain. You may re-gain "lost" power from bad wires. The stock (OEM) spark plug wire should be just fine for natually aspirated applications, such as yours. If you want to go "performance" for cheap. Buy NGK wires. I initially got them because they were cheap and blue. Turns out they are a good brand and they look pretty too.
