1991 Civic stock front springs, etc
Old May 5, 2007 | 10:10 AM
bechtoea's Avatar
Default 1991 Civic stock front springs, etc
In new introductions, I stated I am fixing up a 1991 Civic 4wd station wagon. Right now, I need some suspension parts. I need a good source for two front OEM height springs. I don't see the need in lowering a 4wd. Also need a right side upper control arm as the ball joint is toast.
HELP!!!
Old May 6, 2007 | 09:11 AM
ef4life's Avatar
Default RE: 1991 Civic stock front springs, etc
ball joint go to autozone. or get one off a civic in a junkyard (not recommended). same with the springs, any 88-91 springs will work, but they might lower it a bit unless they are from a wagon dur to different spring rates and the weight of the cars
RyanEJ2
Mar 20, 2008 03:44 PM
LivinLow
Mar 27, 2006 07:46 PM
nemo
Dec 3, 2005 03:43 PM
LivinLow
Sep 26, 2005 07:48 PM
pkfrdh
Mar 22, 2005 11:38 AM
