door chime question
Old May 10, 2007 | 09:48 PM
jason_hann53's Avatar
Default door chime question
heyy. i think that little chime that goes off every time the key is in the ignition and the doors are open, is VERY annoying. i was wondering, would it be stupid to stop that, and how would i go about stopping it?
Old May 11, 2007 | 10:31 AM
mike21190's Avatar
Default RE: door chime question
i think thats themost annoying noise. it only helps me when i leave my lights on and it chimes otherwise it drives me nuts.
Old May 11, 2007 | 10:51 AM
rice99ex's Avatar
From: Utica, NY (home of The Saranac Brewing Co.) :)
I know that if you put the key in the ignition and turn it forward while the door is open it wont make that sound, other than those forst 5 or 6 beeps.If your door is closed and turn the key, then open the door it will go off. Thats the way it is with my car anyway.
Old May 11, 2007 | 10:54 AM
theres a fuse for it, if you can find a fusebox diagram for the one in your interior, pull it out of there
Old May 11, 2007 | 12:22 PM
alright il look for a diagram, thanks flip. i wasnt sure if it was a wire or a fuse, but il just look for the fuse.
Old May 11, 2007 | 12:32 PM
anyone know hwere i could find a fusebox diagram for a 02 civic coupe?
Old May 11, 2007 | 12:54 PM
Mr Mobsta Man's Avatar
Your manual.
Old May 11, 2007 | 09:29 PM
phan10m's Avatar
Will it be the same chime for the lights too? cuz I like the handy leave my lights on chime but I never wear my seatbelt ..i know STFU.. but anyway is there a seperate one or is it all the same fuse
Old May 12, 2007 | 12:10 PM
does anyone know what the fuse that i need to pull would be called in the manual? and would it be in the interior fuse box or under the hood? im thinking interior but im not sure
Old May 12, 2007 | 11:33 PM
so i got it there was a rubber cover on the button taht gets pressed when your door is closed, and behind the cover there was a bolt and i undid it and there was a connector on the end so i disconected it and no more chime
