Crank Pulley
Old Jun 15, 2004 | 07:56 AM
NYC Civic's Avatar
Default Crank Pulley
I know that crank pulley does give a pretty good amount of gain but I remember in the past, someone told it is not a good idea to put a lightweight crank pulley on an engine that's being driven daily. It can do some serious damage to the motor. I forgot why though. Anyone here experience with crank pulley?
Old Jun 15, 2004 | 10:01 PM
lilol89crx's Avatar
Default RE: Crank Pulley
the 1.6 and larger engines use a harmonic balancer type crank pulley to reduce vibrations. a lightened crank pulley does not have this feature. so in the long run you may end up damaging your engine. now a 1.5 does not use a harmonic balancer, so you could use a light crank pulley but you 1.5 pully is already light weight due to no rubber damper.
Old Jun 17, 2004 | 04:19 AM
NYC Civic's Avatar
I don't quite understand about this. I still don't understand how it would damage your engine. Can you explain it to me more about this? Thanks.
ORIGINAL: lilol89crx
Old Jun 17, 2004 | 08:43 PM
lilol89crx's Avatar
a harmonic balancer/damper dampens harmonics which cause vibrations. the 1.6 uses these as the vibrations can cause your #1 main bearing to absorb the vibrations thus causeing bearing damage.
Old Jun 18, 2004 | 03:47 PM
NYC Civic's Avatar
Which other Honda comes with a harmonic balancer? Do you know if the H22A engine also comes with it?
Old Jun 18, 2004 | 04:45 PM
NTX's Avatar
NTX
Most engines made have harmonic balancers.. A lot of the time the pulley and balancer can be seperated.
Karrde
12
Jan 24, 2009 05:09 AM
cain crx
Oct 8, 2006 08:14 PM
02CivicSISLVR
Sep 12, 2006 11:43 AM
ray90813
Jan 10, 2006 05:44 PM
skidbump
May 15, 2005 08:53 PM
