Stripped drain bolt question
Old Jul 8, 2007 | 10:41 AM
mrblades's Avatar
Default Stripped drain bolt question
Hi, the drain bolt for my transaxle on my manual transmissioned1998 civic dx is stripped.A Jiffy Lube guy overtightened months ago and I just noticed it when I went to change the oil. What is the best and cheapestway to fix this? Thanks
Old Jul 8, 2007 | 12:26 PM
mill$civic's Avatar
Default RE: Stripped drain bolt question
Get a pair of vicegrips and try to take it off, and then go to honda and get a new bolt. If you cant take it off yourself, just go get your oil changed by a shop and get them to take it off and put on a new bolt.....and dont go to jiffy lube...
Old Jul 8, 2007 | 05:00 PM
mrblades's Avatar
Sorry about that. I didn't leave enough information. I meant the internal threads are stripped. The drain bolt can't tighten all the waydown into anything. Dang air wrench overtorqued it most likely. Any ideas for this? Thanks
Old Jul 8, 2007 | 05:04 PM
Mr Mobsta Man's Avatar
You could get it re-threaded maybe. I'm not sure tho
Old Jul 8, 2007 | 05:07 PM
civicexracer's Avatar
tap it(hehehe). find out the thread pitch and re-thread it.
looks like this
Old Jul 8, 2007 | 05:11 PM
dfdon's Avatar
id prolly get a new tranny before i threaded it not my fortay
Old Jul 8, 2007 | 05:13 PM
y? its easy and wont hurt anything. just try not to get a rediculas amount of shavings in there and ur fine. its just a drain bolt...if u take the car to a shop, they'll prolly end up tapping it too.
Old Jul 8, 2007 | 08:54 PM
dfdon's Avatar
no i hear u just last time i did it it didnt work out good
Old Jul 8, 2007 | 10:32 PM
Kommando's Avatar
ORIGINAL: mrblades
A tapis pretty easy to use, but I'd take actions to make Jiffy Screwup pay for a new case. Even after tapping, there won't be as much material there for showroom-good threads. You'd need to upsize the plug bolt for that.
Anytime you have somebody touch your car, check their work right after. Even simple things like an oilchange can be screwed up by mongoloids.
Old Jul 8, 2007 | 10:41 PM
JohnnyTEAMDSR's Avatar
give it new threads FTW! and do all the fluid changes your self. if you dont know how, let me know ill pm you steps w/ step by step instuction with pics
