spring not all the way in lower pocket? problem or no?
Old Aug 1, 2007 | 08:11 AM
Default spring not all the way in lower pocket? problem or no?
well i noticed this when i got my new rims put on... one of my rear springs on the drivers side is about 1/2inch from sitting in its little pocket/grove....
i mean its INPLACE... but the spring could be rotated about 1/2inch to the tip of the spring is in the grove where the tip was from stock... is this a problem? or would it be fine?
i havent noticed any poping or anything...
but the tire gap is only SLIGHTLY bigger on that side but nothing noticable unless you finger gap both sides...
i tried to man handle it into the grove BUT the spring wouldnt budge...
i thought i had all the springs set properly when i instaled them and took off the spring compressor but i guess either i didnt or its moved....
should i worry abotu this enough to fix it..... or just leave it?
Old Aug 1, 2007 | 08:30 AM
My04Civic's Avatar
Administrator
Default RE: spring not all the way in lower pocket? problem or no?
i would take it apart and fiddle with it, it should def. be sitting in its seat.
Old Aug 1, 2007 | 09:05 AM
mxs's Avatar
mxs
Fix it
Old Aug 1, 2007 | 09:20 AM
do ya think id be able to put on the spring compressor on the strut while its still on the car? id rather not do a whole bunch of work pulling them off to just turn the spring about 1/4- 1/8th a turn....
i mean the spring is in the pocket BUT the TIP of the spring could be rotated just alittle to touch the STOP slot...
Old Aug 1, 2007 | 09:32 AM
mxs's Avatar
mxs
see if you can just turn it by hand.
Old Aug 1, 2007 | 09:42 AM
ej6buddy's Avatar
definitely needs to be in seated. just about hitting a bump and it coming out a little more, lol.
Old Aug 1, 2007 | 12:15 PM
no i cannt turn it at all.... i tried two handing it and turning it into that slot but its realy tight!
but its inside the pocket BUT say its like a bolt the threaded part...... it would be turned alittle more to where it wont turn any more..
Old Aug 1, 2007 | 12:21 PM
My04Civic's Avatar
Administrator
your going to have to pull the wheel off a and fix it, its for the best!
Juans_MX3
Apr 7, 2010 03:38 PM
nightrider46
Jun 2, 2007 06:23 PM
R35P3KT
Nov 14, 2006 07:55 PM
R35P3KT
Nov 13, 2006 10:11 PM
importcivicus
Mar 19, 2006 04:49 PM
