do i have to remove the bumper if i want to install new head lights?
Old Aug 7, 2007 | 08:17 AM
burgernuds's Avatar
Default do i have to remove the bumper if i want to install new head lights?
Do I?
and do I have to do special wiring if I have a halo or two?
Can I just forget about the halo and not have to go through that?
Old Aug 7, 2007 | 08:22 AM
mill$civic's Avatar
Default RE: do i have to remove the bumper if i want to install new head lights?
To remove the bumper and put in headlights, click this DIY.
For the halos, they are just spliced into your parking lights, or you can run them to a switch, its really not that hard and there are alot of threads on here on how to do it.
Old Aug 7, 2007 | 04:47 PM
TheMoogly's Avatar
Run the halos to a switch.
Old Aug 7, 2007 | 06:10 PM
99lx's Avatar
Is there any advantage to running them to a switch? Lots of people are saying to run them to a switch like running them to the parking lights is bad...
Old Aug 7, 2007 | 08:29 PM
TBon3's Avatar
+1. I'm getting Halos soon for my teg, can't you just wire them you what your existing lights are wired to?
Old Aug 7, 2007 | 08:34 PM
ej6buddy's Avatar
no, because the halos will eventually wear out prematurely because you would turn them on way too much (i.E. everytime you switch your headlight switch). it's best to run them to a switch because you probably won't always want them on with your headlights, especially if your halos are different colors.
Old Aug 7, 2007 | 09:32 PM
burgernuds's Avatar
do i HAVE to remove the bumper?
Old Aug 7, 2007 | 09:42 PM
ej6buddy's Avatar
ORIGINAL: burgernuds
YES, IT WILL ONLY TAKE YOU A COUPLE OF MINUTES THOUGH. AND NO, YOU ARE NOT REQUIRED TO WIRE UP THE HALOS. seriously though, no need for caps.
Old Aug 8, 2007 | 07:14 AM
burgernuds's Avatar
okay thanks
Old Aug 9, 2007 | 11:39 PM
burgernuds's Avatar
even though the instruction says to run it to my parking light... i should run it toa switch? how do i do that? Anything else to know when im installing projector /halo headlights? just plug and play right?
