94 EX - ABS Light Issue
Old Apr 27, 2004 | 02:16 PM
BravoTwoFour's Avatar
Default 94 EX - ABS Light Issue
<FONT face="Arial, Helvetica, sans-serif">I have a 94 EX with 4 wheel disc and ABS. I replaced both axles/CVs and all brake pads. The ABS light now stays on all the time. Used the diagnostic and it indicates the front left speed sensor is faulting. I reset system and it faults again after a few forward revolutions of the wheel. I did not notice any difference between the axles removed and installed but I understand there is to be some ridge or something for sensor to read? I see none. However, I get no diagnostic that front right is faulting and it appears identical to front left. Don't recall straining the sensor wire or anything when the work was done. </FONT></P>
<FONT face=Arial>Appreciate any fix suggestions or posts back with similar experience.</FONT></P>
Old Apr 27, 2004 | 07:25 PM
ImportKid's Avatar
take it in
Old Apr 28, 2004 | 10:06 AM
Spending the time and dough to take it in is a last resort, but I appreciate your reply, ImportKid. Car drives fine although I recognize there could be braking issues. New CVs definitely make a difference. It would seeme to me the ABS is not a complicated fix and possibly its just the replaced axle which is why I was looking for anyone with similar experience or Honda background to offer insight. Comes down to it and I cannot figure it out then I will take it to a specialist.
Old Apr 29, 2004 | 01:47 AM
ZzZzz EH2's Avatar
www.honda-tech.com</P>
</P>
Ask on there, you will get 5 ot 6 different answers but one of them WILL be right man.</P>
</P>
-EH2</P>
Old Apr 29, 2004 | 03:13 AM
lilol89crx's Avatar
did u make sure your new axle is for abs? maybe the new axle doesnt have the reluctor ring. check it out and make sure there is a reluctor wheel on the outter joint.
Old Apr 29, 2004 | 02:27 PM
green98lxsedan's Avatar
that might be the answer. did you ahve to unplug any of the abs sensors and forget to plug them back in?
Old Apr 29, 2004 | 05:08 PM
Thanks for the replies. I did not check new axles for ABS compatibility since I was unaware there was even ABS on the car at the time. I have had it only a few months and it turns out to be a Canadian car, four wheel disk, a bit of a surprise at first. Anyways the two axles' outer CVs are identical - no ridges, lines, reflectors, etc. But the diagnostic only indicates a front left problem. All lines intact, nothing had been removed. I only opened the MC during caliper reinstall. Brakes work fine. Any other ideas? The shop is too damn expensive which is why I did the axles myself.
Old May 1, 2004 | 07:38 PM
The problem was as lilol89crx said; the axles were not fitted with the ABS sensor ring. I put new axles in and corrected the problem. Twice the work but its all done now. I found the ball joint boot is ripped so the right steering knuckle comes out again soon... Any thoughts on that? Thanks for all of your replies.
Old May 1, 2004 | 07:49 PM
lilol89crx's Avatar
replace the dust boot with a poly type. there stronger and more versitile. also good to hear there problem is fixed. that is one of those things that are easily overlooked.
Old May 1, 2004 | 10:31 PM
Does the ball joint need to be replaced or can I just replace the boot? I suppose the boot itself could be done now that I think of it. But man the last thing I wanna do in the foreseeable future is yank on that damn wheel and axle again. Think I'll wait a bit and let my back stop spasming...
