Suspension Product Review Links - what to buy!??!
Old Oct 19, 2007 | 04:08 PM
mxs's Avatar
mxs
Default Suspension Product Review Links - what to buy!??!
Links to the product review section of this site
Springs, Shocks, Coilovers etc. for Double Wishbone Cars (2000 and earlier)
Tein S-Tech springs https://www.hondacivicforum.com/m_332498/tm.htm
Dropzone lowering springs https://www.hondacivicforum.com/m_186165/tm.htm
Tokico HP kit https://www.hondacivicforum.com/m_254166/tm.htm
Dropzone coilovers and shocks https://www.hondacivicforum.com/m_107934/tm.htm
Dropzone springs and shocks https://www.hondacivicforum.com/m_200216/tm.htm
Koni Yellow shocks and Ground Control coilovers https://www.hondacivicforum.com/m_280737/tm.htm
Springs, Shocks, Coilovers etc. for Macpherson Strut Cars (2001 and later)
Tein S-Tech springs https://www.hondacivicforum.com/m_434684/tm.htm
Tein S-Tech springs https://www.hondacivicforum.com/m_200476/tm.htm
Ingalls front camber kit https://www.hondacivicforum.com/m_263243/tm.htm
Ingalls rear camber kit https://www.hondacivicforum.com/m_263245/tm.htm
Megan Racling LCAs https://www.hondacivicforum.com/m_263239/tm.htm
Other Parts
Energy Suspension poly boots https://www.hondacivicforum.com/m_335000/tm.htm
Energy Suspension / Prothane poly bushings https://www.hondacivicforum.com/m_280737/tm.htm
Suspension Techniques rear swaybar https://www.hondacivicforum.com/m_280737/tm.htm
Old Aug 25, 2008 | 06:15 AM
TimRoche's Avatar
whats the deal with those coilover lowering spring kits? are they actually legit? it says it drops 1-4" but something doesnt seem right
Old Aug 25, 2008 | 02:09 PM
which ones are you talking about?
and 1-4" makes sense, coilovers are height adjustable
Old Oct 2, 2008 | 09:14 AM
vonjason's Avatar
Default skunk 2
is a full coil over system what gives a car the nice ride?
or do you need new control arms?
basicly what does each part do?
what do i need to get that nice ride?
Old Oct 2, 2008 | 11:01 AM
xsteinbachx's Avatar
Please read the stickys.
"Links to usefull suspension information"
https://www.hondacivicforum.com/foru...ad.php?t=49092
"Coilover FAQ - Should I get coilovers or springs?"
http://www.norcalcrx.org/tyson/coilover.html
Old Oct 2, 2008 | 12:02 PM
vonjason's Avatar
thanks for the link i new there had to be info on here somewhere
Old Nov 6, 2008 | 12:01 PM
beauregaardhooligan's Avatar
Any suggestions to *raise* the back of my wagon?
I need a little more clearance, especially if I've got passengers or cargo.
Old May 8, 2009 | 11:53 PM
vosleth's Avatar
I have an 02 civic Dx. 2dr. I would like to know what kind of suspension to get. I would like something that is adjustable. Mostly for street purposes, but my civic is a toy not a dd. I need to know some good parts to get... I mean the entire susp. Machpersons, sway bar, bushings, sway bar links. I only want to drop like an inch or two. I am not to worried about price, as I just have to pay shop cost as I am a 3rd year mech. and this is a little off topic but how would I figure out what size of tires I could fit in after all the suspension parts are in?
Old May 8, 2009 | 11:58 PM
what's a machperson?
anyway, get an ASR rear sway bar and ASR rear subframe braces (prevents tearing out the sub frame with the sway bar's tension).
I like H&R springs but if money is not an object i'd get something nicer. Bilstein or Omnipower full coilovers would be nice. There's others out there too, but i'm just basically saying I would get full coilovers. If the full coilovers you buy don't have pillowball mounts, i'd also get some of those. Tein makes some pillowball mounts. I'd get Function7 LCAs.
Energy suspension makes a nice master bushing kit. Get black though, not red. it has graphite in it whereas the red does not, and it makes the bushings last longer or something along those lines.
While you're at it, i'd get energy suspension shifter bushings too.
i'm not sure what you can do for a front sway bar.
Old May 9, 2009 | 11:04 AM
No such thing as just Machphersons. I think you're kind of confused about your suspension, Anything from 01+ has MacPherson struts, it's a design not a product.
http://en.wikipedia.org/wiki/Honda_Civic_Si Look at 96-00
