EP Swaps 2001+ Civics
2002 civic si rsx head swap
Old May 10, 2005 | 06:04 PM
alaskan hb's Avatar
Default 2002 civic si rsx head swap
Does anyone know if the head off the rsx type s is interchangeable with the 02 civic si hb.If so where can I get info and is it worth it??
Old Jun 12, 2005 | 01:11 PM
se7ensectoolate's Avatar
Default RE: 2002 civic si rsx head swap
ORIGINAL: alaskan hb
Yes.
Old Nov 19, 2005 | 01:37 PM
chris_Air_force's Avatar
Yes they are swappable, it is very worth it and pretty simple. There is tons of information on www.ephatch.com check it out.
Old Jan 22, 2006 | 03:01 AM
baker's Avatar
if you feel like 40 hp is worth it... haha
Old Jan 24, 2006 | 04:51 PM
dj_ipirate's Avatar
sure why not?
Old Apr 21, 2006 | 09:55 AM
ficodecko's Avatar
how much should this cost? and will i have to buy a new k20a2 computer?
Old Dec 27, 2006 | 11:51 PM
Ben's Avatar
Ben
It'll cost you close to a thousand....
Old Mar 7, 2007 | 02:38 PM
ficodecko's Avatar
kpro is the best but the a2 ecu will work it just wont run that great
Old May 7, 2008 | 05:16 AM
soprano19's Avatar
MAN you guys need to learn a little bit more about the Kseries before you start jumpin in and saying yes.............. first off its not a direct SWAP.... your going to need a lot of **** before you start the project, your pretty much going to need everything for the( injector/ spark plugs/ new head gasket/ intake mani. gasket ect. you will need to change out all of the fluids, AND YOU WILLLLL NEED to run KPRO for it to work.
bbspell22
Sep 3, 2008 01:51 PM
nightrider46
Aug 15, 2007 01:31 PM
RowensSpecV
Jul 17, 2007 05:57 PM
Kenneth Ames
Mar 20, 2007 02:42 PM
alaskan hb
May 10, 2005 09:24 PM
