2 things, redline and gas....
Old Dec 15, 2007 | 06:06 AM
point break 92's Avatar
Default 2 things, redline and gas....
okay this has been discussed before but i can't seem to find the thread. so, what gas does this damn thing want? i've given it 93 and 89....and i just put 87 for the first time cause i'm going poor. and it's the same thing isn't it?
also, i still will never understand how my 92 dx 1.5L sohc, redlines at 7,200 rpm...what rpm does it really give out on givning power though? this is driving me nuts
Old Dec 15, 2007 | 06:20 AM
DelawareDon's Avatar
Default RE: 2 things, redline and gas....
Use whatever gas your owner's manual recommends, which I suspect is 87 octane. Anything else is just a waste of money and will not make your car run better.
Old Dec 15, 2007 | 06:28 AM
i don't have an owners manual lol don't need it! alright i'm also assuming it's 87 too. but what's up witht he redline dude?
Old Dec 15, 2007 | 06:43 AM
ORIGINAL: point break 92
As mentioned by DelawareDon, if your car runs fine on 87 octane gas, then keep using it.
The ECU cuts off current to the fuel injectors at about 7,400 rpm to protect your D16Z6 engine from being damaged. This function is called "Fuel Cut-OFF Control" (see picture).
Old Dec 15, 2007 | 07:08 AM
dude, i love you. so i have power up until 6,650?
Old Dec 15, 2007 | 07:16 AM
Yes (for the D15B8).
Old Dec 15, 2007 | 09:03 AM
i figured, but quick question. why does the limiter go to 7,200 for? were they smoking or something?
Old Dec 15, 2007 | 09:55 AM
KOFMIGUELB's Avatar
ORIGINAL: DelawareDon
But doesn't premium gas helps your motor to be clean and helps fights build up deposits in the engine.
i understand cheap gas is bad for your engine.
Old Dec 15, 2007 | 09:58 AM
The limiter is intended to protect against blowing the engine. It doesn't correspond to the rpm for best performance.
Also high octane gas isn't inherently any "cleaner" than regular. It may have more additives in it if it is a name brand but that's a tiny difference. If you engine doesn't knock when you use regular, use regular.
Old Dec 15, 2007 | 10:01 AM
Good question. I don't have an answer.
(Pardon the threadjack: Welcome back mk378!)
