EG Swaps 1992-1995 Civics
Does Wheel Bolt Pattern change with an engine swap?
Old May 22, 2005 | 04:19 PM
dooka4u4's Avatar
Default Does Wheel Bolt Pattern change with an engine swap?
I have a 1994 Honda Civic DX Sedan. Currently it has the stock D15B7 engine in it. I plan on doing a B16A2 or A3 down the road at some point. The question is... when you replace the axles in the car does that also change the bolt pattern for the front wheels. I am looking into buying some 4 bolt wheels and I want to know if they will work with the new engine/axles.
I am a newbie... I do not plan on doing the engine install myself. A friend will help me install it (who knows what to do) or I'll have it professionally installed.
Thanks for help in advance, Jim.
Old May 22, 2005 | 05:46 PM
neon3kgt's Avatar
Default RE: Does Wheel Bolt Pattern change with an engine swap?
the axles just have a spline on one end. then they slip into the hub. the hub is what has the lugs on it, just replaceing the axles will keep the same bolt pattern.
Old May 22, 2005 | 06:12 PM
LEVIII's Avatar
even upgrading to Integra brakes front and rear will not change the bolt pattern, so long as its not type-r 5 lug, but thats abvious
Old May 22, 2005 | 08:21 PM
dooka4u4's Avatar
Thanks for the info... I really appriciate it. -Jim
olengrumpy
May 8, 2007 10:25 AM
Imari007
Nov 13, 2006 02:07 PM
Imari007
EK Swaps
Nov 12, 2006 10:50 PM
civicexracer
Sep 8, 2006 03:24 PM
audiophile
Feb 25, 2006 08:50 PM
