Car died, getting no spark
Old Dec 17, 2007 | 09:05 PM
mybrokenblinker's Avatar
Default Car died, getting no spark
So guys, I was driving today, and with no symptoms, my car just died. Won't start back up. I'm pretty sure it's spark related because it won't start when ether is sprayed into the intake either. Timing light is picking up nothing. Anyways, I'll tear into it tomorrow probably, but if you have any advice or theories, let me know.
Old Dec 17, 2007 | 09:09 PM
Default RE: Car died, getting no spark
The coil in the distributor would be a prime suspect (picture 1). The Ignition Control Module (ICM) is also a candidate (picture 2). But first make sure that the distributor is getting battery power. If not, check whether fuses #41 and #42 in the under-hood fuse/relay box are blown.
Old Dec 17, 2007 | 09:41 PM
it's a 96 coupe ex
Old Dec 17, 2007 | 09:47 PM
See edits in my first post.
Old Dec 18, 2007 | 12:00 AM
extreme's Avatar
i would say replace the coil
Old Dec 18, 2007 | 04:54 PM
well, after running the tests, it's not the coil...
Old Dec 18, 2007 | 05:04 PM
The ICM input test should tell you whether the ICM either is not getting battery power or is bad.
Old Dec 18, 2007 | 09:17 PM
So if all the tests were normal (i did them all) and it still is not getting any spark and the coil is fine, that means it's the icm? that seems to be what the directions indicate.
Old Dec 18, 2007 | 09:19 PM
ORIGINAL: mybrokenblinker
Yes, that's correct. It's a process of elimination test.
Old Dec 19, 2007 | 04:52 AM
FIRST, in such a case check that the distributor rotor turns when you crank the engine. If it doesn't (almost certainly because the timing belt is stripped), you will have a crank but no spark situation.
Often a bad coil will pass the resistance test. Try to draw sparks from the secondary terminal on the coil to a grounded wire. If you can get sparks but they are very small and weak, it's a bad coil.
