Need help deciding...
Old Dec 22, 2007 | 08:11 AM
jdizel's Avatar
Default Need help deciding...
I'm purchasing an Injen intake this week. Should I go with cold or short ram?? I can't decide...money isn't the issue.
I like the CAI, but I heard you only notice the gains when you're in the mid to high rpms. This true? With short ram I heard you notice gains during initial acceleration. Please provde insight on this.... I also live in Wisconsin...lots of snow and a decent amount of rain...CAI might become an issue for me. Has anyone had both installed on their cars, can you really tell a difference?
Old Dec 22, 2007 | 08:20 AM
my05civic's Avatar
Default RE: Need help deciding...
i can't emphasize enough the minimal amount of difference in gains between a cai and a sri. you will barely, BARELY notice the difference if you bought the two. one thing that'd be evident is a different tone (because one is longer/deeper), but other than that, you can just pick one.
here's how theory works: the cai is located in the bumper or somewhere where cold air is readily available; the sri is located in the engine bay, where air is warmer than the air that the cai is exposed to
here's what counters the theory: the cai will get the cooler air, but as it travels up the longer tube, it'll get heated slightly because it passes by the engine; the sri will have slightly better throttle response than a cai because the air will travel faster to the engine
each have their pros/cons. obviously if it snows a lot and you get a LOT of rain (eg. flooding of 1+ feet of rain) you do not want a cai. but if this isn't the case, then take your pick
Old Dec 22, 2007 | 08:40 AM
jdizel's Avatar
So will I get a deeper sound with the CAI...just so I understand correctly?
Old Dec 22, 2007 | 08:54 AM
point break 92's Avatar
pretty much the same thing. but yes deeper. the short ram just has more...umph? and sounds more agressive imo
Old Dec 22, 2007 | 09:00 AM
jdizel's Avatar
Anyone have any sound clips of the two?
Old Dec 22, 2007 | 03:23 PM
ic892003's Avatar
go on you tube and type it in, if snow and rain is the issue and you dont want to get hydrolock, you can get a bypass valve put on the cai but it might decrease gains that you will get, if anuything go with the sri its cheaper and a less chance of hydrolock
Old Dec 22, 2007 | 03:42 PM
tknaub's Avatar
i would get the CAI (i have one) and water/snow is not an issue as long as it is not 1+FT (as my05civic said) but if your seriously worried about hydrolock, then buy the SRI. the difference between the 2 are about 1-2 HP. but like others have said above....choose one, i know with injen you will be happy.
Old Dec 22, 2007 | 04:43 PM
ic892003's Avatar
or yoou can go with an ebay cai or sri and smack on a K and n filter, same difference
Old Dec 23, 2007 | 07:17 AM
jdizel's Avatar
Thanks everyone...I'm probably gonna go with the Injen Short Ram...I'll post pics when it's installed
Old Dec 23, 2007 | 12:40 PM
tknaub's Avatar
good choice!
