CRAZY plug wire question
Old Dec 26, 2007 | 08:23 PM
Mylittlecivic's Avatar
Default CRAZY plug wire question
I dont know if anyone has ever thought about this or i may just be crazy for it. But could you use the Spark plug wires from a 93 2.2 vtecprelude on a 95 1.6 vtec civic. if you did what would it do?
What makes spark plug wires different from year to year
Just a question to rack your minds
Old Dec 26, 2007 | 08:27 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: CRAZY plug wire question
Well, you're talking totally different cars. Are you talking about the engine harness to the ECU? Then wire colors could be similiar since thye are both in the Honda family, but they will differ.
Old Dec 26, 2007 | 08:30 PM
ORIGINAL: danomatic93
sorry about that i ment to put in there the spark plug wires<--edited
Old Dec 26, 2007 | 09:50 PM
koots's Avatar
I'm not too sure in this application, but most plug wires have different resistances and lengths (kind of go hand in hand to a degree) and might not work in your application. stick with the OEM wires though, the aftermarket ones don't make that much difference in even a mild civic. (I/H/E and other stuff)
Old Dec 26, 2007 | 09:58 PM
June 2010 ROTM
ORIGINAL: koots
...most plug wires have different resistances and lengths (kind of go hand in hand to a degree) and might not work in your application. stick with the OEM wires though...
^Ditto, at least get ones for your car.
Old Dec 27, 2007 | 08:42 AM
guy is offering me nology wires for 40 bucks used 2 months.
i may get them see just to see how they do
Thanks for you inputs. if i get them ill let you guys know how they turn out good or bad
Old Dec 28, 2007 | 01:24 PM
Ok so i got the wires and put them on. They work the only differencesare that they .4 ohm and my other ones are 7., then the rubber boot on top is just wider.
Old Dec 28, 2007 | 09:00 PM
2KCIVICSIG's Avatar
wires is one of those things that cars like from factory,(OEM)
Old Dec 29, 2007 | 02:40 PM
autozone wires suck ngk are good and they are 58 dollars so i went ahead and got those wires. no biggie really
Old Dec 29, 2007 | 08:35 PM
another update about those plugs,
alright i gotta take it out today for a litte drive and wow what can i say. I can actually tell there is a difference.The exhaust is deeper for one, feels like it drive with ease now.
* i dont know if my wires were just bad or if these are that good, wires before tested good
