Canada, Over Seas & Elsewhere Not from the states? Everywhere else post here.
car shakes at 100km/h
Old May 24, 2005 | 05:11 PM
tos's Avatar
tos
Default car shakes at 100km/h
i just bought a 98 civic hatchback
runs great and everything but when i take it on the highway, and i'm going 100km/hr it starts to shake, everything shakes, why's that?
Old May 24, 2005 | 08:02 PM
cdn86gt's Avatar
Default RE: car shakes at 100km/h
Could be a number of things from tires to suspension. Does the car bounce more than 3 times if you push down on a fender then release. This would indicate a shock is on its way out. Another thing to check would be to lift the car and push and pull each tire to check for play. If a belt has shifted in the tires you might want to try swapping out with a spare set, if you have them. Also if your in Canada check and see if you have snow tires on, they aren't really good at high speeds. Hope some of this helps.
Old Dec 6, 2006 | 09:26 PM
SilverSedan's Avatar
Don't forget the simple things...check your lugnuts, you might be loosin a wheel. OR get your wheels balanced, if you got something out of balance, that usually shows up at highway speeds
Old Dec 15, 2006 | 03:41 PM
streetheat's Avatar
I'd say its a broken belt of your tires need to be balanced
Old Feb 21, 2007 | 10:16 PM
waldo's Avatar
In the winter time, one can sometimes get vibration when snow is stuck in the wheels after a snow storm or after driving through thick snow. Usually what will happen is the vibration will gradually fade away after 10-20 minutes but then you have to remove the excess snow if it doesn't completely go away. But like someone mentionned, it could be a balancing problem, and I've already seen a bad batch of winter tires.
Best regards,
Waldo
Old Feb 24, 2007 | 07:57 AM
patto_001's Avatar
hmm.. suspension it seems ?..
Old Feb 25, 2007 | 01:06 PM
scottsilke's Avatar
I would get your wheels balanced, and your alignment checked
CivicPicchio1.4
Mar 11, 2012 06:10 AM
Eun
Apr 4, 2007 05:20 PM
bjscivic
Dec 14, 2006 06:37 PM
oldschool
Sep 1, 2006 12:00 PM
san
Mar 23, 2006 11:18 AM
