Throwout bearing or Input shaft Brearing?!
Old Jan 22, 2008 | 08:02 AM
itsmycivicduty's Avatar
Default Throwout bearing or Input shaft Brearing?!
I have a 90 civic hatch with the stock 1.5 d15 and 4 speed tranny. There is a noise any time the clutch is engaged and it goes away wnen the clutch is disengaged. The sound goes away after a few seconds, sounds like something is slowing down. One mechanic drove it with me and said I need some tranny work in the way of bearings. The car kas 117k on it. Another mechanic said it is the throwout bearing. I could see reason in both. Your educated opinion is?
Old Jan 22, 2008 | 08:39 AM
Default RE: Throwout bearing or Input shaft Brearing?!
Well, I've been reading around the forum after I posted this and I can get a 5 gear tranny with 109k on it for 300 from a 90 civic. should I just do that and put in a new clutch? Then I'll have 5 gears. woo hoo How can I check the bearings on thejunkyard tranny to make sure it isn't crap?
Old Jan 22, 2008 | 10:48 AM
SovXietday's Avatar
Input Shaft Bearing fo sho, it's not the throwout.
Yeah sure the trans should bolt up just fine.
Old Jan 23, 2008 | 07:11 AM
I know of a great backwoods shop that quoted me 300 bucks for the swap and a clutch (plus the cost of the tranny).A shop in the bigger city quoted 1400. That is quite a difference. The cheap one does better work also
Old Jan 23, 2008 | 08:41 AM
StifflersMom's Avatar
Cat Fuсker
1400 for a transmission replacement labor-wise is a ripoff....in a shop it's maximum a 3 hour job...
Old Feb 14, 2008 | 05:00 PM
cheeks404's Avatar
my civic is doing the same thing but mine has become quite suvere How long should it take the put in the new input shaft bearing?
bonbon
Nov 3, 2011 08:17 AM
01civicsed
Aug 15, 2009 01:08 AM
trustdestruction
Mar 9, 2009 12:38 PM
mtchu736
Jan 25, 2009 12:23 PM
mr honda
Mar 8, 2008 07:47 PM
