16 " wheels help
Old Apr 19, 2008 | 04:02 PM
beaudan1's Avatar
Default 16 " wheels help
Hi im new to the import scene and new to this site. I just bought a 96 civic dx H.B. I havenew 16"wheels. My ? is can i run 205/50/16 without a problem? It is at stock heighth for now. I havetruck on 265/35/22 and it rides like crap.All and any help would be appreciated.
Old Apr 19, 2008 | 05:30 PM
Default RE: 16 " wheels help
the thinner the tires sidewalls the worse the ride.....
i dont remember what tire size is correct for 16s tho. but that size sounds about right.... it wont be as smooth of a ride from your original 13-15s depending on what stock wheels ya got.
those truck tires must be thin as hell.... lol no wonder they ride to ruff!
IMO 20s are the largest i would go on my fullsize truck. only way i would go larger is if i got some massive swaper tires on a lifted truck
theres two things that killl your ride quality.... lowering and larger rims.
Old Apr 19, 2008 | 08:37 PM
ej6buddy's Avatar
what width are the wheels you currently have? that determines tire size as well.
Old Apr 20, 2008 | 06:44 AM
beaudan1's Avatar
motegi racing FF7 16x7 +42 offset.
Old Apr 20, 2008 | 06:50 AM
The tire size sounds about right for a 16x7 (I really don't feel like checking right now lol), and the offset is perfect (you need at least a +38mm offset to avoid rubbing, so a +42 will work great).
If I'm correct, dx's came stock with 13" steelies... that being the case, your ride quality isn't going to be near as good as it is with the stock wheels, but it should still be liveable.
(welcome to the forum, btw)
Old Apr 20, 2008 | 07:37 AM
personally, I would go with a little smaller sidewall. I like a 40 on 16s, though the ride will be a little rougher, on stock suspension it should be more than livable, and youll get much better handling with the smaller sidewall, as well as it not looking like big balloon tires.
Old Apr 20, 2008 | 08:09 AM
^ You forgot to mention that the speedo will be less accurate then. It'll only be something like 0.8% off, but it should still be mentioned
but +1 on the better handling with a smaller sidewall
Old Apr 20, 2008 | 08:22 AM
beaudan1's Avatar
it came stock with 175/70/13. i looked on the gallery here to see if anyone had 205/50/16 and i found a couple of people running this size and also lowered and they didnt look to balloney. i guess my biggest concern is ride quality. thanks to everyone for your responsees and help.
Old Apr 20, 2008 | 09:25 AM
if your biggest concern is ride quality, then youre on the right track[sm=smiley20.gif] but your speedo will actually be quite a bit off with the 50 series. the 40 series would get it within about 1%.
Old Apr 20, 2008 | 09:37 AM
I just checked... the 50-series will put your speedo off by almost 6% (when your speedo will read 60mph, you'll actually be doing about 56)... I could've sworn the 50-series was closer to stock than that.
