converting an auto ecu to manual???
Old May 6, 2008 | 09:29 AM
panaphobic's Avatar
Default converting an auto ecu to manual???
i found a quick write up on this, but it didn't help me really. i did a bunch of other searching and can't find any useful info.
i bought a p28 ecu, but me being stupid didn't think to check the serial number on it. happens to be an automatic ecu. i have a standard and i just did a mini-me swap, and i believe that this is my problem.
does anyone know exactly how to convert the automatic ecu to a standard ecu???
the write up i found has this info. it was "borrowed" from hondata........
"How to convert an automatic ECU to 5 speed specs
First, let's find out if we have an automatic, or a 5 speed ECU. If you don't want to plug it in and throw code 19 (automatic trans lockup solenoid) to find out it is an automatic ECU, then look at the code on the side. If the second to last number is a 5, then you have an automatic ECU (for OBD-1 USDM ECUs). If the 2nd to last # is anything but a five you have an ECU for a 5 speed. If you have a jdm obd-1 ecu, look at the last 3 digits: 900 or 901 will be an automatic. If you were unfortunate enough to get an automatic ECU, then read on and learn how to cure all your problems.
The following information was all obtained from Hondata.com and the picture was graciously borrowed from them as well.
For Jdm Pr3/Pw0 ECUs:
Move the jumper from R68 to R67 (both locations are to the left of the ROM)
For USDM OBD1 ECUs (p28):
Underneath the ROM there is a row of resistors labelled with RP__ . Remove RP17 and install a jumper across RP18.
For JDM OBD1 ECUs:
RP18 (in the same location as usdm) needs to be lowered in value from 2.4k to 1.4k ohms"
problem is that i have a jumpers on BOTH RP17 AND RP18.
this is my ecu (sorry for the bad pic, it's the best i can get right now....)
has anyone done this before????? what do i do? and please don't say "get a different ecu."
any help would be greatly appreciated!!!!
Old May 6, 2008 | 10:51 AM
danomatic93's Avatar
June 2010 ROTM
Default RE: converting an auto ecu to manual???
Look at the Auto/Maunal section...
This is one I did 2 weeks ago...
Desolder the resistors RP17 and RP18.
Then, solder a jumper across RP18.
Done.
If that doesn't make sense to you, have someone else do it for you!!!
A jumper is simply a wire (0 ohm resistor, thus no resistance).
Old May 6, 2008 | 11:13 AM
panaphobic's Avatar
i thought they meant to put a resistor in for RP18. i understand what you mean though. thanks for the pic and the quick response. i really, really appreciate it!!!
Old May 6, 2008 | 11:21 AM
panaphobic's Avatar
oh i forgot to ask, do you have to remove any else?
Old May 6, 2008 | 11:24 AM
June 2010 ROTM
You don't need to, but you can also remove the Auto transistors IC15 and IC16
Old Aug 2, 2010 | 08:19 AM
_Blues_'s Avatar
Hey there!
Just stumbled upon this on Google because I have a P2J-J62 ECU here and want to convert it to manual... (it's for the JDM EK3 [D15B] w/ CVT - OBD2a)
Does anyone of you know how to do the trick for OBD2a ECUs and could help me by telling me what to do with it? Or do the jumpers and resistors in the auto / manual selection section just have to be set up the same way like in any other OBD2a manual ECU, for example a D16Y7 one?
Sorry for any bad english, I'm from Germany...
Thanks in advance for your help!
Erik
Old Aug 2, 2010 | 10:25 AM
You can't do it on OBD2, from what I have read.
P2J huh? That's the 3-stage VTEC ECU. Manual ones are nearly impossible to get over here in the US.
Old Aug 2, 2010 | 10:43 AM
_Blues_'s Avatar
Thanks for the quick answer, even though it doesn't help me a lot.
Well I know that it's the 3-stage VTEC ECU, but unfortunately "J62" is the CVT one. I accidentally bought it, not because I wanted to do a 3-stage VTEC Swap but rather because I needed an ECU for a EUDM EK3 Engine (114hp VTEC-E) and someone would have threwn it away otherwise - regarding that price I didn't really ask for or worry about the ECU code because he told me it was an "EK3 ECU". Now it turned out that it's the 3-stage one and I was wondering if it could be turned into a manual one so I can sell it or maybe get myself a 3-stage VTEC head.
Old Aug 2, 2010 | 11:47 AM
How doesn't my answer help you? I just said the ECU can't be converted to manual on an OBD2 ECU.
Old Aug 3, 2010 | 08:06 AM
_Blues_'s Avatar
Well it would have helped me to achieve my aim if it was possible to convert it into a manual one. It can't help me to convert it, thus it was informative, but did not really help me. :P
