What engine does the 90 integra gs have? and does anybody know the life on that engine?
Old May 7, 2008 | 02:01 PM
shroomy07CEX's Avatar
Default What engine does the 90 integra gs have? and does anybody know the life on that engine?
I'm finding my friend a car and we found a really nice manual 90 integra super clean, but it has 141,000 miles and i dont know what the life expectancy is on that engine, or What engine it is for that matter. all i know is it has 160 hp. Thanks for the help guys
Old May 7, 2008 | 02:59 PM
Hailchristian's Avatar
Default RE: What engine does the 90 integra gs have? and does anybody know the life on that engine?
B18A1 [ul][*]NON -VTEC[*]Found in: [ul][*]1990-1993 Acura Integra usdm "RS/LS/GS" [ul][*]Displacement: 1834 cc[*]Compression: 9.2:1[*]Bore: 81mm (3.2in)[*]Stroke: 89mm (3.5in)[*]Rod Length: 137.01mm (5.394")[*]Rod/Stroke Ratio: 1.54[*]Programmed fuel injection[*]Power: 90-91 Only: 130bhp (97kW) @ 6000 rpm & 111ft·lbf (150N·m) @ 5000 rpm[*]Power: 92-93 Only: 140bhp (100kW) @ 6300 rpm & 117ft·lbf (159N·m) @ 5000 rpm[*]Transmission: 90-91: S1, cable[*]Transmission: 92-93: YS1, cable[/ul][/ul][/ul]im pretty sure its a good engine...my friend has one and he hasn't had anyproblems with it so far.
Old May 7, 2008 | 10:16 PM
s0ulj3r's Avatar
motors will last 250k+ w/ good maintenence keep up.
Old May 8, 2008 | 07:36 AM
Whether the oil has been changed frequently is easy to spot, take the oil filler cap off and look for sludge on the rockers and the top of the head. If you see clean metal (may be stained brown, but should not have crusty sludge) it has been well maintained, or somebody cleaned it up.
black03si
May 25, 2006 02:54 PM
andryuha
Mar 9, 2006 04:45 PM
ekhonda96
Jan 26, 2006 06:30 PM
2k1hondacivic
May 21, 2005 08:28 PM
Standuphonda
May 13, 2005 01:45 AM
