AC, 1998 civic
Old Jun 18, 2008 | 09:51 AM
davew2's Avatar
Default AC, 1998 civic
So my AC cycles on and off a lot, and ive checked the usual stuff. Heres the history and what ive found out so far.
New compressor, refilled by mechanic. Low side reads about 35psi, low side pipe gets cool but not cold. Condensor fan works, relay checks out, AC is better in the morning when its cold out. AC cycles on and off when its really hot out.
Whats the problem??
Old Jun 18, 2008 | 11:16 AM
Default RE: AC, 1998 civic
The compressor cycles off for 3 reasons:
Evaporator has reached 40 F (clearly not the case here)
Engine rpm too low (it's about to stall)
Too much high side pressure (seems like that would be it)
You need to measure both pressures to diagnose. Or maybe the pressure is normal but the high pressure switch is triggerhappy.
i have the same problem, except my compressor's not new.
i tried doing the r134a conversion and it seemed to help a little but not enough.
bhollie
Aug 12, 2015 06:55 PM
froggy780
Apr 30, 2011 09:23 PM
WKD_DRGN
Sep 12, 2010 04:28 PM
froggy780
May 27, 2004 07:27 PM
froggy780
May 19, 2004 08:46 PM
