honda civic rims
Old Jun 26, 2008 | 04:40 AM
str8upg's Avatar
Default honda civic rims
sup people i just passed my test not that long ago and couldnt believe it when i managed to get a honda civic as my first car, ive been driving it around for a couple months now and need to do something to it cos its all stock, ive been looking at alloys and found the perfectset but am not sure whether they will fit or not here's the specs
ive got a 1994 honda civic bali hatchback
the rims are 16x8 inches / 35mm offset / 4x100 PCD and choice of 195/45/16 or 195/40/16 tyre size
any help would be much appreciated
Old Jun 26, 2008 | 07:09 AM
sde780's Avatar
Default RE: honda civic rims
what brand and model are they? it should fit, your bolt pattern is 4X100
Old Jun 26, 2008 | 12:29 PM
colby_666's Avatar
aren't you supposed to have a wider tire on that size rim?? i looked and it said that for that size tire it is for a 6-7.5 inch rim
http://www.1010tires.com/TireSizeCal...?action=submit
Old Jun 26, 2008 | 12:38 PM
Davo's Avatar
Well i dont know the numbers right off hand. i have 18`s on my 94 coupe. a lil big i know. they came with the car. ill try again tonight to post some pics.
Old Jun 26, 2008 | 12:55 PM
those are probably too wide and will rub around corners for sure, and yea those tires are not wide enough for those rims. You're better off with 16"x6.5"s or at the widest 16"x7"s. With tires, on a civic the widest you should probably go is 205.
Old Jun 26, 2008 | 01:07 PM
str8upg's Avatar
this is the website for the rims
http://images.google.co.uk/imgres?im...%3Den%26sa%3DN
copy and paste that all the info is there do you think they will fit
Old Jun 26, 2008 | 01:42 PM
i mean, they'll fit, but you'll probably have rubbing issues because they're 8" wide.
Old Jun 26, 2008 | 01:45 PM
str8upg's Avatar
do you think theres any way (cheaply) i could get around that
Old Jun 27, 2008 | 01:21 PM
str8upg's Avatar
do u think if i got wheel spacers it would work
Old Jun 29, 2008 | 06:18 AM
WhiteRabbit1021's Avatar
I ran 8.5s on my civic and I was fine. Lowered and everything.
