Smoked Tail lights?
Old Jul 8, 2008 | 09:33 PM
Jarrodr's Avatar
Default Smoked Tail lights?
Hi,
I have a '97 Civic 2Dr, How do I mod my tail lights... I want to make them smoked, by just customizing the current lights I have now?
Thanks
[IMG]local://upfiles/32479/92604D0FBBB44F3FB6B80F410798ADAB.jpg[/IMG]
Old Jul 8, 2008 | 09:54 PM
Default RE: Smoked Tail lights?
search. search, my friend. you might find this: http://www.HondaCivicForum.com/m_83030/tm.htm
Old Jul 8, 2008 | 10:10 PM
Jarrodr's Avatar
Thanks trustdestruction,
I've read the thread... I'll try one of the methods out and get back to you.
Old Jul 9, 2008 | 08:55 AM
chunkbird's Avatar
Mine are three light coats of black spray paint, did the job nicely. I did the same to my wife's van - and the van is still not cool
Old Jul 9, 2008 | 11:14 AM
rsrayray81's Avatar
my 94 civic taillights are tinted with regular window tint. came out really nice.
Old Jul 9, 2008 | 02:42 PM
macbeth18288's Avatar
^+1 tint film
painting you lights FTL
Old Jul 9, 2008 | 02:55 PM
chunkbird's Avatar
ORIGINAL: macbeth18288
^+1 tint film
Paint cost less than a buck, still lets light through, and looks the same... how much to get the tint film?
Old Jul 9, 2008 | 03:34 PM
VHT Nite-shades FTW..... make sure its VHT! high quality stuff!
either way you do it i HIGHLY sugest wet sanding your lights smooth... remove any scratches, raised lettering before tinting either way. dont worry it will look alittle cloudy after sanding but just tint over the lights with them clean and your golden...... just let the spray tint dry well before touching it!
BUT BE WARNED!!!!!!!!!!! by tinting your taillights you are hindering others from seeing your brake lights as well durin gthe day! at night time its no problem BUT during the day the sun reflecting off the tint makes it really hard to see brake lights...
ive tinted, sanded, tinted sanded SEVERAL TIMES till i found the good VHT Nite-shades spray tint that lays down smooth and easy! and if you dont think they turned out good just sand the tint off with some 2K grit wet sandpaper and then with some simple fine rubbing compound or a nice wax to shine the taillights right up to make them just as good if not better than when you started since now they will be scratch free and shiny
ive had them done several times.....
and the lettering why it looks bad if you dont sand it off smooth before tinting!
just keep sanding till its all gone... helps if you spray paint around the area or something so you know when youve sanded them off.
start out with some thin coats and work your way darker till you think its right.. the more layers or thicker you paint the less light will shine thru! but remember if you tint to dark its only alittle sandpaper and about 1hour or less to sand it down all off with some 2K grit wet sandpaper. you can probably use 1K but i didnt want to risk any scratches to deep....
if you want to step it up to be SAFER for day time driving which i HIGHLY SUGEST... some extra lighting helps... i used some red superflux leds BUT i didnt like how it turned out so right now im rocken factory taillights again till i can buy enough leds to redue my taillight setup....
my new taillights will have abunch of flexled strips in the lower clear section. gonna use red and some yellow strips to keep it safe for daily driving! i baked the outter taillights apart to put these new led strips in. i thought about the inner taillights BUT they busted while trying to seperate so im gonna stick with just the outter taillights being lited.
thats just a TEST with one 9.5 blue led strip i had laying around...
heres a few videos i have of the few different types and darker layered tint...
http://ca.youtube.com/watch?v=6sogcMcvlLo
http://ca.youtube.com/watch?v=rppuXbR9jwo
just a few things for you to consider.....
ALSO another helpfull think is before tinting your taillights tint the back/side/edges first before tinting the main taillights.... what happens is light leaks in from the sides/corners between the body/taillight and during the day it makes it look like your edges are red... you can see how it is in this picture below.... see the far left of the lense corner/edge....
so turn the lights face down and spray the paint/tint around the sides to kinda go behind the lense. and if you get tint/paint on the exterior front of the lense just sand it off and then tint it.
kinda hard to describe i hope you understand what i was trying to say....
File Type: jpg
Old Jul 9, 2008 | 05:26 PM
addiction, you inspired me to do mine tonight. I went to advance auto parts and they didn't have any, but they guy i talked to had done his before and he said this stuff he used works better. They sell it at our local hobby shop, and he happened to have a few extra cans in the trunk, so i bought one off of him. I got home and did my taillights. They look 10X better. I'll get pics soon. Only thing that sucked about doing mine is I have a Del Sol, so I have the 3rd brake light above the rear window. I had to do that one too. I ended up just taping around it and doing it while it was on the car. It's kinda a pain to get it off.
Old Jul 9, 2008 | 05:35 PM
well from the stuff i used VHT is the best... i bought two types of spray tint off ebay and even the film. i still got that weak @ss film stuff to, but the other tint stuff i threw in the trash after trying 3times! and it fish eyed every time! and yes i cleaned the crap outta the lights before painting and it still fish eyed every time!
