subwoofer problem
Old Jul 13, 2008 | 04:34 PM
nineteenninetynine's Avatar
Default subwoofer problem
i was driving the other day and my subwoofer would pop in and out. so i turned the music off and you could hear a pop every so often so im guessing thats the power to the subwoofer thats going off and on...
any help???
Old Jul 13, 2008 | 04:53 PM
ShaTownCivic's Avatar
Default RE: subwoofer problem
Go over all of your wiring. Make sure you don't have a short somewhere. When your subwooferis on does it sound good? Might be blown. I say just check your wiring.
Old Jul 13, 2008 | 05:04 PM
Sigracer10's Avatar
unfortunately theres not just one thing that we could tell you is the problem. It could be a variety of things such as a bad ground connection on the amp, a bad speaker wire connection betweenthe sub and amp, a bad power wire connection at the amp or the battery, or even a bad set of RCAs.
What I would do first is go over evey connection of the whole system and check that everything is securly and properly connected. If that still doesn't try running a new temprorary set of RCA cables and see if that helps.
Old Jul 13, 2008 | 05:10 PM
ya its a huge could be anything deal....
i had a inline fuse before that had a bad joint that would oddly enough loose conection turning my amplifier off from power not geting to the amp. could also be a loose speaker conection on the amp, on the sub box, on the inside of the box/ on the sub itself.
could also be a small wire sliver from the wire that shifts over and touches another terminal shorting the amplifier.
Old Jul 13, 2008 | 05:22 PM
alright thanks ill check everything then get back to you guys.
Old Jul 14, 2008 | 10:23 PM
cyberx32's Avatar
Its almost always the ground, so make sure its grounded right, you might even have to ground the headunit
Bostonhoodhop
Jun 26, 2008 07:12 AM
blkcivicman05
May 9, 2005 10:53 AM
nike1051
May 3, 2005 03:28 PM
trihonda
Mar 31, 2005 02:53 AM
Remmy
Mar 1, 2005 12:30 PM
