hissing/squeaking sound
Old Jul 16, 2008 | 12:11 PM
nealkal's Avatar
Default hissing/squeaking sound
I have a question about a sound I heard when i switch gears. I have a 2000 civic ex manual transmission. I hear a hissing or squeaking sound during the point when i put in the clutch until a second or two after I'm in gear. It's not loud or anything, but I wanted to know if this was normal or not. It's done it for as long as I can remember.
Old Jul 16, 2008 | 12:21 PM
nealkal's Avatar
Default RE: hissing/squeaking sound
i also notice the sound if im at low rpm's and i press far down on the gas pedal
Old Jul 16, 2008 | 04:43 PM
Smokin94civic's Avatar
throw out bearing is going bad in the tranny
Old Jul 16, 2008 | 06:21 PM
^+1 either that or you have a mouse and a snake stuck and living inside your transmission.
Old Jul 17, 2008 | 06:01 AM
nealkal's Avatar
what causes this? how difficult is it to replace? Is it worth replacing?
Old Jul 17, 2008 | 06:51 AM
civic_eg_ls's Avatar
ORIGINAL: trustdestruction
^+1 either that or you have a [color=red]mouse and a snake stuck and living inside[color=black] your transmission.
[sm=ummmmokay.gif]
Old Jul 17, 2008 | 06:55 AM
Old Jul 17, 2008 | 10:08 AM
ORIGINAL: civic_eg_ls
[sm=ummmmokay.gif]
he said he has a hissing/squeaking sound
Old Jul 17, 2008 | 11:07 AM
silverbullet01's Avatar
or may also be your exhaust with a long slit and sucks in the air and blows it out...does it happen when u downshift as well?
Old Jan 16, 2009 | 07:34 AM
nealkal's Avatar
i finally got this resolved. I'm not sure exactly what it was but when i replaced the timing belt, water pump, a/c belt, alt belt, and p/s belt. the sound went away. i just don't know which one of those fixed the problem.
