Input Shaft Bearing? Please confirm.
Old Mar 7, 2009 | 08:48 PM
Default Input Shaft Bearing? Please confirm.
Hey guys, I'm gonna be buying my clutch kit, flywheel, axles, and lower ball joints soon and there's also a bearing I'm gonna have to replace.
I think it's the Input Shaft Bearing, but I just want to make sure i've diagnosed the problem correctly before I go buying stuff.
When I am at idle, there is a "shhhhhhhhhhhhhhhhhhhh" noise. When I push the clutch pedal, the noise immediately goes away, and when I let off the pedal it comes back. I can hear it while driving and it makes the typical worn bearing sound. It increases with the RPMs. Noise stops if I push in the clutch.
So, does this sound like the Input Shaft Bearing to you guys?
-Thanks
Old Mar 8, 2009 | 07:16 AM
gwl's Avatar
gwl
Its usually the throwout bearing that will make some noise until you press your foot on the clutch.
Old Mar 8, 2009 | 10:09 AM
I thought it was the other way around... throwout bearing makes noise when you push in the clutch
Old Mar 8, 2009 | 12:23 PM
jprommel's Avatar
Angry Admin
Old Mar 8, 2009 | 12:49 PM
guys, throw out bearing gets used when you push the clutch pedal. if it were the throw out bearing, it would be making noise when i push the pedal, not when it's resting.
Old Mar 9, 2009 | 09:06 AM
gwl's Avatar
gwl
Thanks for clearing that up. I always thought it was the other way around.
Old Mar 9, 2009 | 09:41 AM
Trust, sounds like you have the right diagnosis. Have you seen this DIY thread, which I believe is for a 94 Civic? In the service manual, the Input Shaft Bearing is apparently called the Clutch Housing Bearing.
Old Mar 9, 2009 | 12:27 PM
There's also a bearing on the other end of the input shaft inside the transmission. Either or both of those bearings could be bad and making noise.
Old Mar 9, 2009 | 12:38 PM
Thank you very much for that link. I have been looking for a DIY and couldn't find one, this makes me feel much more comfortable with ripping open the transmission.
Do you recommend I just go ahead and replace both then?
Can you tell me where the bearing is in this picture? (regardless of whether it's visible)
And which one is the input shaft? Sorry, never been inside the transmission before. lol
bonbon
Nov 3, 2011 08:17 AM
01civicsed
Aug 15, 2009 01:08 AM
mtchu736
Jan 25, 2009 12:23 PM
mr honda
Mar 8, 2008 07:47 PM
itsmycivicduty
Feb 14, 2008 05:00 PM
