We're adding and testing new features:  Create your Garage, used it? Give us some feedback here.
Go Back   HondaCivicForum.com > Your Ride > Appearance
Reply
Thread Tools Search this Thread Display Modes
Old 03-23-2009, 09:43 PM
danomatic93's Avatar
danomatic93 danomatic93 is offline
Send a message via AIM to danomatic93
Default DIY Parking Pole on LHD Civic
This is if you want to mount your super sweet JDM yo parking pole on the passenger’s side for a LHD Civic. This way the pole can actually be of use and not be just a JDM goodie.
This DIY is done with an EG switch (up and down toggle switch) and an EG pole.
Quick Operation Vid:
When extend, the tip lights up:
Suggested Tools:
-Dremel
-Soldering Iron
-Heat Shrink Tubing
-Screw Drivers
-Safety Glasses
Wiring:
The pole will have 4 wires coming from it:
Yellow/Red – connect to Yellow/Red on Switch
Yellow/White – connect to Yellow/White on Switch
Red – connect to Red wire on Parking Light
Black – connect to Black wire on Parking Light
The switch will have 4 wires coming from it:
Yellow/Green - connect to ignition +12 volts
Black – connect to ground
Yellow/White – connect to Yellow/White on Pole
Yellow/Red - connect to Yellow/White on Pole
If you get a used pole you’ll probably have to extend the wiring. Properly solder and shrink tube the connections.
Modifications:
Since the mounting bracket is set up for a RHD vehicle you’ll have to bend it the opposite of how it is currently bent. Keep the same angle.
Now, I tried a bunch of different ways of mounting the pole (that's why there a ton of holes in it). It seemed that the best way was the use all the original holes. I also cut the bracket and bent the edge a little for better fitment.
If your pole didn’t come with the security nut that mounts on top on the bumper you can make one. Here’s the one I had to make. I found a hard plastic grommet and used a dremel to get it to the right size. For structural integrity, I used epoxy to fill the voids. Also, not pictured, I cut two notches on the top for installation and removal.
Original piece on the left, modified piece on the right:
Install Steps:
1. Remove bumper.
2. Line up where pole will come out and mark it.
3. Cut hole in bumper, BE CAREFUL, you one get on chance.
4. Mount Bracket to Fog light bracket and screw tight the top security nut.
5. Connect the wiring to the corner light and run the other wires into the cabin and connect accordingly.
6. Enjoy your Super Sweet JDM Yo Parking Pole!
To remove this ad, register today or login if you already are registered!
__________________
Coupe Council Member # 45
Coupe Council! We roll as a family!
Build Thread: http://www.hondacivicforum.com/m_576697/tm.htm
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 03-23-2009, 09:52 PM
WellFedHobo WellFedHobo is offline
HCF's Well Fed Hobo
2000 Honda Civic
Send a message via AIM to WellFedHobo
Where do you mount the button on an EG?
__________________
Old 03-23-2009, 10:03 PM
It mounts in the armrest blank spots. If you don't have an armrest, in the e-brake branks.
__________________
Old 03-24-2009, 02:48 PM
SPLAT's Avatar
SPLAT SPLAT is offline
Nice, im still thing if i should do this or not.
Old 03-24-2009, 03:10 PM
justinwebb justinwebb is offline
nice writeup but what is the purpose?
__________________
My site: www.shweet.org Check It Out!!!
March 09 Ride Of The Month
Old 03-24-2009, 06:45 PM
96CIVICcakes 96CIVICcakes is offline
Quote:
i was thinking the same thing
Old 03-24-2009, 06:48 PM
sfazngiants sfazngiants is offline
1999 Honda Civic
Send a message via AIM to sfazngiants
got any pics of it on your car?
__________________
Old 03-24-2009, 07:09 PM
Quote:
LOL, honestly it's a JDM toy...
...But It's purpose it is aid in parallel parking and indicate where the front corner of the car is for tight situations.
This pole hides when not in use. But when it is needed, use the switch to extend it (when extended the light turns on) and you can see where that front corner is. That way you don't have to worry about hitting cars, objects, people...
...Luckily I know how to drive, so the pole it purely decoration for me. But for others that fail at life, it is necessary.
So, yes, it's a little gizmo that is for the most part unnecessary. BUT IT'S SOOOO SUPER SWEET JDM YO!! lol
__________________
Old 03-24-2009, 07:11 PM
315 Customs's Avatar
315 Customs 315 Customs is offline
1997 Acura Integra
Send a message via AIM to 315 Customs
Quote:
Originally Posted by danomatic93 View Post
but it's soooo super sweet jdm yo!! Lol
mad jdm tyte yo
__________________
-Kevin
<~~ HCF Security Guard
315 Customs: So how are you dealing with Micheal Jacksons death?
jprommel: its rough on me
jprommel: he touched me in so many ways
Old 03-24-2009, 07:23 PM
Quote:
Not yet, sorry. It's poring and I don't want my camera to get wet.
Soon.
__________________
Reply
Tags
bumper, civic, ef, honda, images, install, installation, jdm, parallel, parking, pole, poles, switch, wire, wiring
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
AMSOIL - Performance Oil Technology
K&N Engineering
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaCivicforum.com content, comments, or advertising. HondaCivicforum.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaCivicforum.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
