98 Civic Ex Wire colors Alarm/Remote Start install...
Old Mar 26, 2009 | 07:15 AM
chasemclemore's Avatar
Default 98 Civic Ex Wire colors Alarm/Remote Start install...
I would like to see if anyone has the wire colors for these following wires, I used to install and its been a while and forgot how to test for some of these... most are found undneath column
12v constant
door lock (-) or (+) pulse I forgot
door trigger (-) or (+) pulse I forgot
accessory 1
accessory 2
starter
ignition
tachometer
Old Mar 26, 2009 | 07:38 AM
Default Found it, here it is for you guys if you need it later on
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 Yellow Ignition Switch Harness
Accessory White/Black Ignition Switch Harness
Tach Blue Coil
Neutral Safety Wire Black/Blue (-)
Brake Switch Green/White Brake Switch
Trunk Pin Blue/Black (-) Driver's Kick or behind Radio Light Green (-)
Parking Lights Red/Black Driver's Kick Panel or above Fuse Panel
Head Lamp Red/White left. Red/Blue right at Steering Column
Door Trigger Light Green/Red (-) Anti-Theft Module behind Radio Green Connector
Door Lock Green/White (-) Above Fuse Panel or at Anti-Theft Module
Door Unlock Green/Orange (-) Behind Radio Green Connector
Driver's Lock White/Red Driver's Door
Driver's Unlock Blue/Red Driver's Door
Passenger Unlock Yellow/Red Passenger's Door
Horn Wire Blue/Green (-) Steering Column or Green Connector behind Radio
Windows Up LF=Red/Blue, RF=Blue/Yellow, LR=Green/Yellow, RR=Yellow
Windows Down LF=Red/Yellow, RF=Blue/Orange, LR=Green, RR=Yellow/Green
zerojett
Sep 24, 2012 12:55 AM
dwalsh77
Oct 11, 2011 07:00 AM
xsdudztx
Aug 14, 2007 05:45 PM
xsdudztx
Aug 9, 2007 07:45 PM
t rev
Aug 9, 2005 06:22 PM
