Replacing radiator support
Old Apr 2, 2009 | 04:16 PM
vtecaddict's Avatar
Default Replacing radiator support
im taking out the front bulkhead/ radiator support and replacing it with a del sol's for my project. do i need to put a bracer in while im removing the old one so there is no shifting in the frame or anything?
Old Apr 2, 2009 | 04:27 PM
i dont believe so. i didnt brace mine.
but the support doesnt really support much weight. so it doesnt have to be perfect. only think you could posibly have off is the bumper cover and front fender bolt. which can simply be fixed by opening the holes alittle bit
but if in doubt you can go ahead and tachweld a quick crossbeam along the top.
but the frame rails and all the motor mounts should hold everything with no problems. but if you have the motor removed then it maybe posible for the frame to tweak alittle.
Old Apr 2, 2009 | 04:33 PM
vtecaddict's Avatar
alright cool... i have the part coming into the dealership tomorrow, so im taking everything back off tonight so i can do this whole swap right. instead of the brackets i had made... i figured you would know, i should've just pm'ed you.
Old Apr 2, 2009 | 04:41 PM
no problem. its not a difficult install or removal if ya have some power tools
after you swap one youll wonder why they total out a civic from a high impact wreck so much when its just sheet metal
im happy i fixed my 96. only thing i miss is the power options like my EX had but the manual tranny makes up for the loss when it comes to fun to drive.
Old Apr 2, 2009 | 04:52 PM
vtecaddict's Avatar
hey quick question... wheres a good place to buy long lasting spot weld drill bits?
Old Apr 2, 2009 | 05:29 PM
no idea ive never used one.... a simply punch and hammer and afew drills works good.
or a air chisel works great!!!!!! thats what i used one mine... at first i tried to drill them out but shortly i just tried the air chisel and it worked very fast so i just ditched the drill and kept air hammering away and within 1 min i had the whole thing poped off. and i just used a grinder to smooth the old spot weld areas and also a hammer and dolly to straighten out the slightly bent flanges around the frame rail.
Old Apr 2, 2009 | 05:59 PM
vtecaddict's Avatar
im lookin into drilling out the welds... that way i can either keep or sell the front bulkhead to recoop some cash from this front end swap. anyone have the approx size of the welds? or ill look tomorrow morning when i get back to the shop to start workin on the car.
Old Apr 3, 2009 | 07:07 AM
well the support isnt very easy to remove in good condition.... the lower part on the rail is a huge PITA to find all the spot welds!
even tho its not a 92-95 this is pictures of my frame rails... its spot welded in a bunch of places!
http://i40.photobucket.com/albums/e2...s/DSC00240.jpg
http://i40.photobucket.com/albums/e2...s/DSC00239.jpg
http://i40.photobucket.com/albums/e2...s/DSC00233.jpg
theirs my welds but it was pretty much guessing where i could get a good weld. it took a bunch of air hammering to get mine to come off all the way. luckely a air hammer is pretty fast.
but IMO its not worth trying to save..... its only about 100-150bucks for a new one online. and thats where people would look first for a new one or a dirt cheap junk yard.
but its your call. good luck with the swap!
Old Apr 4, 2009 | 06:04 PM
gwl's Avatar
gwl
Check this website. Search for spot weld remover.
http://www.eastwoodco.com/index.jsp
lokalmotive
Jun 5, 2006 07:48 PM
kimsuprapa
May 25, 2006 10:54 AM
redline.
Jan 19, 2006 02:04 PM
sy_82_nj
Dec 3, 2005 10:01 PM
MARKTOM
Nov 9, 2004 03:51 AM
