Motor mounts
Old May 12, 2009 | 06:57 PM
Justin13's Avatar
Banned
Default Motor mounts
My motor mounts have been bad for a while. When i rev it the whole damn thing moves. and im thinking thats why my car takes off like a turtle. So should i get stock mounts cause im on a low budget or are there better mounts for a low price.
Also how do you replace motor mounts? Is it a smart idea to have a shop do it becuase remember. low budget.
Thanks
Old May 12, 2009 | 07:20 PM
ej6buddy's Avatar
1- it takes off like a turtle b/c it has little to no power.
2- make sure the stock mounts are even bad, stock mounts have a lot of give for comfort.
3- you will need to support the whole vehicle with jacks and support the motor with a block making sure nothing will move, then remove the mounts.
Old May 12, 2009 | 07:31 PM
Justin13's Avatar
Banned
i mean it takes off so slow it wont even chirp them but once it gets past like 15 or 20 it goes pretty good. i can keep up with my freinds Ford taurus SHO V8. its almost like it stalls for a split second then takes off
Edit: i know the mounts are bad. they just look all cut up and nasty
Old May 12, 2009 | 07:42 PM
ej6buddy's Avatar
Old May 12, 2009 | 07:47 PM
Justin13's Avatar
Banned
ill look into some stock ones tomorrow.
if its not the motor mounts then why does my car take off so damn slow. i mean i know it only has 120hp MAX and its an AUTOMATIC but its abnormally slow. i drove this one girls car that was exacly the same as mine. D16y7. same everything just this one was stock and it was way way faster
Old May 12, 2009 | 08:08 PM
ej6buddy's Avatar
you'll be lucky to have 90-95whp.
Old May 14, 2009 | 09:33 AM
Justin13's Avatar
Banned
really? i was looking on the internet and it said somewhere around 110. but i got a new air filter and did an oil change and my car seems to be running alot better. ill still get motor mounts soon becuase i got a job interview today so hopefully i get it and i get mounts asap.
Old May 14, 2009 | 10:40 AM
+1
Quoted from Wikipedia
"D16Y7 * Found in:
o 1996-2000 Honda Civic DX/VP/LX/CX
o 1996-97 Honda del Sol S
+ Displacement : 1,593 cc (97.2 cu in)
+ Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
+ Compression : 9.4:1
+ Power : 106 hp (79.0 kW, 107 ps) @ 6400 rpm
+ Torque : 103 ft·lbf (14.3 kg/m, 140 Nm) @ 4,600 rpm
+ Redline : 6800 rpm
+ Rev-limiter: 7200 rpm
+ Valvetrain : SOHC (4 valves per cylinder)"
Yea, you may have 110, but only 90 or so is making it to the wheels. A new air filter and all that tune up stuff with only restore lost HP from having a dirty filter, or bad spark plugs etc etc. If you can keep up with a v8, 235 hp and 230 ft·lb torque with your automatic, there's gotta be something wrong with the Ford driver....
Old May 14, 2009 | 12:57 PM
ej6buddy's Avatar
You just fixed your idle making your throttle response smoother, not necessarily faster.
Old May 14, 2009 | 10:20 PM
Justin13's Avatar
Banned
well i got the job today so hopefully i can really get going on my car
